2011 Superduty Down Pipe - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BUCK2, this thread has received 29 replies and been viewed 5981 times.
post #1 of 30 (permalink) Old 10-14-2009, 11:11 PM Thread Starter
BUCK2's Avatar
I crawled all over th new Superduty in the Rain on Sunday at the Texas State Fair. I was shocked to see the down pipe for the Turbo!! It was crimped in the middle just like my old 97 power stroke was!!
It looks like hte after market guys are going to need to get everyone a new down pipe for sure!!!!
The Turbo seems to sit between 1/2 to 3/4 of the way back on the valley betwwen the heads. The engine bay is completely full!! It almost looks like a Nasa project under the hood.
It will be interesting to see how the truck performs.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #2 of 30 (permalink) Old 10-15-2009, 01:24 AM
Mafia member #6
Rutcutter's Avatar
Im interested to see,why in the hell cant ford see what it takes to make some more Hp and not have it crimped on the down pipe for the Turbo....
I cant wait to see,I hope to have one of the 1st one's off the line.
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #3 of 30 (permalink) Old 10-15-2009, 02:22 PM
Got Torque?
ralphinnj's Avatar
Images: 80
Is it a 3" crimped pipe or a 5" crimped pipe? If it is larger, it won't matter. As long as there is sufficent interfacial area.
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline
post #4 of 30 (permalink) Old 10-15-2009, 02:27 PM
is here and there.
Rcannon's Avatar
Images: 11
But wouldn't a restriction, any restriction, change things? asking because I don't know.
Rcannon is offline
post #5 of 30 (permalink) Old 10-15-2009, 02:33 PM Thread Starter
BUCK2's Avatar
It looks like a 3 inch, and it looks like it is smahed almost in half. If any of you have ever seen the 96-98 down pipes, they where horrible!! I will try to get a picture of it today, I am goin back out there.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #6 of 30 (permalink) Old 10-15-2009, 02:34 PM
Got Torque?
ralphinnj's Avatar
Images: 80
Yes, when comparing, say, a 3" round to a 3" round that has been crimped, he11 yeah! But if you create essentially an ovular shape to get through a narrow opening that has as much interfacial area as the round shape, you lose very little. Key is how abruptly the transition is made, so if Ford went with a cheaper, crushed approach, it will have kinks and will make it possible for aftermarket vendors to improve the design. Having a big fat round DP is great, but my guess is there is not enough room and that is why they flattened it.
Other Rides:
The Following User Says Thank You to ralphinnj For this addition to TDG:
Rcannon (10-15-2009)
post #7 of 30 (permalink) Old 10-15-2009, 02:36 PM
Got Torque?
ralphinnj's Avatar
Images: 80
Another way to look at this is that if they used a 3" pipe and crimped it and they are making 400HP, we will probably see a nice pump by improving the breathing with a larger, better-flowing DP and unrestricted exhaust pipe.
Other Rides:
post #8 of 30 (permalink) Old 10-15-2009, 02:48 PM
bushpilot's Avatar
remember the turbos on the 6.7L SHARE the same shaft.
and dont forget this is an INSIDE OUT motor....the in-take is on the
OUTSIDE of the head (where conventional motors have the exhaust manifold).
the EXHAUST exits from the VALLEY or INSIDE ports of the Heads.
Don R.
Truck Audio,
bushpilot is offline
post #9 of 30 (permalink) Old 10-15-2009, 03:04 PM
Got Torque?
ralphinnj's Avatar
Images: 80
Don, are you saying that due to the location, there simply is not a lot of room, so crimping is mandatory?
Other Rides:
post #10 of 30 (permalink) Old 10-15-2009, 03:24 PM
bushpilot's Avatar
no im just saying that the positioning of the turbos is likely related to the shared shaft.
the pipe make be crimped simply because of the BUILD order & how the insert the motor
into the frame/truck body.
clearly they dont have to crimp the pipes (look at all the aftermarket solutions available
for prior years)...why they do it is beyond me.
Don R.
Truck Audio,
2011 Suburban HD w/ diesel? ccampb1346 Duramax 2011+ (LML) 73 10-15-2011 05:24 AM
First Look: 6.7L 2011 F2/350 ! bushpilot 2011+ 6.7L Power Stroke Diesel 110 10-01-2009 06:48 AM
2011 duramax BriteWhiteRam Duramax 07.5-2010 (LMM) 22 08-29-2009 03:39 AM
New Pics of 2011 SD uga33 2011+ 6.7L Power Stroke Diesel 17 08-28-2009 08:46 PM
