6.7L Downpipe Picture - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeremiah, this thread has received 20 replies and been viewed 12700 times.
post #1 of 21 (permalink) Old 10-24-2009, 07:42 PM Thread Starter
Banned
We were talking about whether or not this was going to be restrictive? What do you guys think?
Jeremiah is offline
The Following User Says Thank You to Jeremiah For this addition to TDG:
Scorpion6.7L (10-28-2009)
post #2 of 21 (permalink) Old 10-24-2009, 08:22 PM
Absolutely not.
You compared this to the old 7.3 PSD from the mid 90's, and it isn't even close to that old design. No crimps and no sharp corners. Should flow perfect.
2008 F-350
KEM 345 tuned.
My pics;
http://community.webshots.com/user/GeorgeC1959
George C is offline
post #3 of 21 (permalink) Old 10-24-2009, 09:31 PM
UpstateDieselGuy's Avatar
Nothing to worry about. I bet that they could have fit a regular bend in there, but opted to have a little extra clearance. That piece could change with a body change down the road as well. Chris
SOLD
UpstateDieselGuy is offline
post #4 of 21 (permalink) Old 10-28-2009, 02:26 AM
Dually Club #3
jdydiesel's Avatar
I think not. The flare of the pipe will help with the crimp that was made for clearance. Should flow the same volume as a mandrel bent pipe.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
The Following User Says Thank You to jdydiesel For this addition to TDG:
Jeremiah (10-28-2009)
post #5 of 21 (permalink) Old 10-28-2009, 02:28 AM
Dually Club #3
jdydiesel's Avatar
Side bar: Is that an oil filter that I see to the right of the flex plate? Did Ford go away from the oil filter on top of the engine? If so that sucks!!!!!!!!
Jason
post #6 of 21 (permalink) Old 10-28-2009, 12:10 PM Thread Starter
Banned
after seeing the setup in person and to be quite honest... i think it's better... u can get two men and a baby around that filter it is out in the open and it's straight up and down... while its draining just unscrew and screw a new one on.... simple. no taking gaskets off and putting new ones on and dripping oil across the front of your truck and those filters are like half the price!
plus, remember ford didn't make the 6.0 and 6.4, that wasn't their design...
Jeremiah is offline
post #7 of 21 (permalink) Old 10-28-2009, 12:36 PM
Got Torque?
ralphinnj's Avatar
Images: 80
Is that pipe (the round part) 3", 3.5" or 4"? Hard to tell. I agree with those above that the way the bend is done, it is NOT restrictive. But that assumes that the pipe itself is of a large enough diameter. I am sure it is fine for the lower flow stock DPF/DEF exhaust setup, but rip all that stuff off and add a tuner, and if it is only 3 or 3.5, it may not be enough. It looks fine though, just wondering about the size.
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline
post #8 of 21 (permalink) Old 10-28-2009, 12:41 PM Thread Starter
Banned
It is at least 4" i saw it in person and it was considerably bigger than my stock down pipe
Jeremiah is offline
post #9 of 21 (permalink) Old 10-28-2009, 01:39 PM
Dually Club #3
jdydiesel's Avatar
How close is the exhaust pipe to the oil filter? Is there going to be a heat issue?
Jason
post #10 of 21 (permalink) Old 10-28-2009, 05:12 PM
that thing is gonna rock!
Scorpion6.7L is offline
picture Imbiggerthanyou Site Information 5 02-02-2008 04:16 AM
Need a picture 4cstr 1994-2003 7.3L Power Stroke 3 06-09-2007 11:26 PM
6.4l TT PICTURE...... BROKER 2008-2010 6.4L Power Stroke 19 09-29-2006 07:32 PM
Okay.....Who got their picture taken Timbeaux38 The Parking Lot 4 07-01-2005 03:02 PM
