Please explain something to me - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tfunk88, this thread has received 15 replies and been viewed 2631 times.
post #1 of 16 (permalink) Old 12-15-2009, 09:26 PM Thread Starter
tfunk88's Avatar
So, when Ford came out with the F450 pick-up in 2008 they touted it's 33,000lb GVWR and 24,500lb towing capacity when equipped with the 4.88 axle ratio. Then (supposedly due to customer complaints about fuel mileage) they dropped the 4.88 axle ratio and magically the 4.30 ratio had the same 33,000 GVWR and 24,500lb towing capacity when before it was significantly less.
The new 2011 F450 has smaller wheels and can't possibly fit the same size brake rotors as the 08-10 model years. I read that it has a GVWR of 13.5k lbs, around 1k lbs less than the 08-10 model year 450. Yet it has the same GVWR of 33,000lbs of the 08-10 models.
Do factory tow ratings mean anything?
tfunk88 is offline
post #2 of 16 (permalink) Old 12-15-2009, 10:13 PM
It all has to do with engineering. If the engineers are not scared of the lawyers, they can do what ever they want. Tow ratings are really relative.
first_ford is offline
post #3 of 16 (permalink) Old 12-15-2009, 11:33 PM Thread Starter
tfunk88's Avatar
That's basically what I'm saying...
Ford touts the 2008 F450 with it's class-leading tow capacity, but only with the 4.88 rear end. Then magically the 4.30 rear end gets the same rating, 4,000lb higher than it was before with NO changes to the truck, when the 4.88 isn't available anymore. Doesn't make sense. what are the ratings based on in the first place?
Don't get me wrong, I love my 2008 F450. It has the 4.30 rear end and will tow whatever I'll need it to. But that still doesn't make me like the manufacturer's playing around with the ratings.
Hey, is your truck an auto or manual? Wanna trade if it's a manual?
tfunk88 is offline
post #4 of 16 (permalink) Old 12-19-2009, 12:04 AM
Baldguy5.0's Avatar
Does anyone know when FORD changed the F450 rear gears to 4.30 and if they, after that ,still offered the 4.88s?
8" lift
37x13.5R20 Toyos
20" Diamos
AFE Stage 2 CAI
AFE 4" Downpipe back DPF delete
H & S Mini Max
PIAA 4000K Head and Fog lights
Alpine 505
Bushwacker FF
Custom Interior painted stuff
Recon clearance and mirror lights
Baldguy5.0 is offline
post #5 of 16 (permalink) Old 12-19-2009, 02:51 PM Thread Starter
tfunk88's Avatar
They offered both gear ratios at first, then later in the 08 model year (I believe Job 3 trucks) only the 4.30 rear was available. In the chassis cabs you can still get 4.88. you can also purchase the 4.88 gears, there's a thread where a guy posted info about it. Mine is a 4.30, I've driven the 4.88 and it is a lot more fun to drive, more responsive, especially with an automatic. Fuel mileage isn't too good, though. I think I'd rather have it, though, except for the few times I take a long trip without towing.
tfunk88 is offline
post #6 of 16 (permalink) Old 12-19-2009, 06:55 PM
Super Moderator
John_G's Avatar
Let's start off with the fact that higher numbered gears are easier on the trans and cooling system.
Testing and validation TAKE TIME, Ford is NOT going to publish a GVWR/GCWR until they are SURE the cooling package, engine and transmission can take the load and meet very rigirous engineering specs. This is best demonstrated by the fact that Ford trucks build LESS underhood and engine temperature towing the same loads compared to ANY of the competition.
The brake system is not a matter of size as much as engineering.
I vote for LIBERTY!
John_G is offline
post #7 of 16 (permalink) Old 12-19-2009, 07:58 PM
Got Torque?
ralphinnj's Avatar
Images: 80
So basically, what John is saying is that the 4.30's had the capability all along, and probably when the Ford marketing guys heard the backlash regarding the fuel economy issues with the 4.88's, they thought about ways to overcome it. Obviously, gearing is one way, and as John said, they did the testing and the 4.30's could also meet the previous claimed performance. The implication is that very likely, the 4.88's can do a lot more than the rating they have been advertised to deliver. So maybe the 4.30's are pretty close to their limit at 24.5K towing limit, but the 4.88's might do 28-30K at the same level of stress. There are obviously other factors, like the brakes, but for sheer pulling capacity, I think the implication of the 4.30's being "the same" is that this actually means the 4.88's can do more.
Black 2003 F350 Dually, Nothing Stock
Other Rides:
Black 2006 300C SRT8
Black 2012 CTS-V (630HP)
Black 2008 Mercedes E550
ralphinnj is offline
post #8 of 16 (permalink) Old 12-20-2009, 12:45 PM
Ford Motorhead
Parts Jimmy's Avatar
The 400 hp compensates for the change from 4.88 to 4.30 plus the shorter tire height also requires less gear. Until I see the brakes and rotors I will reserve comment.
2000 Ford F350 7.3
4" MBRP Exhaust, Donaldson/Motorcraft Air Induction System,
Ford AIC, Bilstein Shocks,
Timbren Overload Springs,
4850 lbs, Code L Front Springs
Northstar 8.5 Adventurer
My Pictures
Parts Jimmy is offline
post #9 of 16 (permalink) Old 12-20-2009, 01:50 PM Thread Starter
tfunk88's Avatar
I agree with you that the 4.88's are more capable than what they were rated at...my question is more about what are tow ratings worth? There must be some reason Ford rated the 4.30's at one level and the 4.88's at a higher level, both ratings LOWER than what the trucks are actually capable of. What makes me question the whole thing is that Ford rated the truck with 4.30's at 20,500lb. Then not too long later, with no changes, it is rated at 24,500lbs. Why wasn't it rated there in the first place? I can't imagine they hadn't tested the truck fully before it was released and knew already that it was capable of that. And why weren't the 4.88's rated higher?
tfunk88 is offline
post #10 of 16 (permalink) Old 12-20-2009, 01:53 PM Thread Starter
tfunk88's Avatar
Huh?
tfunk88 is offline
Can someone explain this..? blackcloudCTD95 The Parking Lot 37 01-17-2008 02:39 AM
Please explain this setup. 06bowtie_guy Medium and Heavy Duty 15 01-15-2008 12:38 AM
can someone explain??? little2000 1994-2003 7.3L Power Stroke 4 12-12-2007 01:53 AM
Please explain this for me.. wideopen The Parking Lot 30 03-17-2006 01:58 PM
