Difference between F250 & F350... and 100 isnt the answer..lol - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigBud, this thread has received 45 replies and been viewed 110357 times.
post #1 of 46 (permalink) Old 01-28-2010, 12:45 AM Thread Starter
I was wondering the difference between the F250 and F350? Is it suspension? Rear?
I hear so many opinions from people that dont really have a clue... So I fugured I would pose it to guysto get a real answer.
Thanks in advance
Bud
BigBud is offline
post #2 of 46 (permalink) Old 01-28-2010, 12:55 AM
Spring strength
john rambo is offline
post #3 of 46 (permalink) Old 01-28-2010, 01:07 AM Thread Starter
So its basically the same truck with a higher payload? Does that mean a big difference in the ride when empty?
BigBud is offline
post #4 of 46 (permalink) Old 01-28-2010, 01:09 AM
scotty32's Avatar
Images: 3
Tire were also my f250 has one ton suspension from factory, most people i know get duallies because ur tires dont were as much when loaded
scotty32 is offline
post #5 of 46 (permalink) Old 01-28-2010, 03:07 AM
The 350 also has thicker axles.
Don't waste your money on a 250 when you can buy a sronger truck for only a few hundred dollars more.
2008 F-350
KEM 345 tuned.
My pics;
http://community.webshots.com/user/GeorgeC1959
George C is offline
post #6 of 46 (permalink) Old 01-28-2010, 04:33 AM
jd87's Avatar
taller rear blocks and gearing options. that's it. suspension, frame, and axles are the same. This is of course comparing SRW's. Don't quote every word on the 2011's, since obviously I haven't worked on one yet, but it's been that way for a while now.
...on edit: was gonna look up some part numbers, but there's pretty good info below.
Finished rebuilder 2005 F250 Power Stroke CC SWB FX4 XLT, 2.5"F/1"R skyjacker lift kit, diamond-plate bed caps, Line-X, Sonic Blue Pearl, Billet grille inserts, 17" Mickey Thompson Classic II's, 35" Hankook Mud Terrain's
Current Project: 97 F350 Power Stroke CC LWB XLT 4x4, sideswiped, 62k miles.
jd87 is offline
post #7 of 46 (permalink) Old 01-28-2010, 04:41 AM
HARLEY6LF250SDU's Avatar
Images: 6
Thanks in advance
Bud
Ok Bud, I will try to explain so that it's clear as mud.......lol
A Ford F250-F350 SRW (single rear wheel only)
has the SAME wheels, brakes, axle, frame, body parts, bed/tailgate etc. THE ONLY differance is the rear springs and payload.
Now that being said, if you are going to be using your truck for gooseneck or 5th wheel pulling, a F350 is the better choice because of the weight over the rear axle in bed. (higher payload) A DRW F350/450 would be a more stable ride, because of the wider track and increased payload over a SRW F250/350.
Now ride quaility is even tougher, a Long box F350 will ride smoother than a Short box F250. But short box to short box a F250 is smoother, a F350 sits about 1 1/4 inches higher between the top of the tire and the bed.
This info is from the 2010 source book, 2011 not completly out yet.
2010 F-250/F-350/F-450 SD Pickups: Spring Specifications — Rear Leaf
Super Duty Series/Model
Combined Rating @ Ground (lbs.)
No. of Leaves
Total Thickness @ Pad (in.)
Overall Length (in.)
Width (in.)
Deflection Rate (lbs. per in./ Spring)(1) (2)
Rating Each @ Pad (lbs. per Spring)
Main Leaf & Auxiliary Spring (Including Spacer)
F-250 Pickup(3)
6100
6
4.55
66.3
3.00
349/654/1174
3133
F-350 SRW Pickup
7000
6
4.55
66.3
3.00
349/654/1174
3133
F-350 DRW Pickup
9000
6
4.42
66.3
3.00
448/930/1800
4289
F-450
9500
4
4.54
66.3
3.00
542/1107/1506
4323
Main Leaf Only
F-250 Pickup
6100
5
2.98
66.3
3.00
348/685
2695
(1) Pickup and Box Delete models include two-stage, variable-rate springs.
(2) Lists first stage/second stage/third stage as applicable.
(3) Auxiliary rear spring available and included with Camper Package and Heavy Service Package for Pickup Box Delete only.
Towing Capacity is the SAME for SRW
• Maximum conventional towing capacity is 12,500 lbs. for Single Rear Wheel (SRW) models with either the 6.4L Power Stroke® V8 or the 6.8L V10 engines
• Maximum conventional towing capacity is best-in-class(2) 16,000 lbs. for F-450 Dual Rear Wheel (DRW) models with the 6.4L Power Stroke engine, 15,000 lbs. for F-350 DRW with 6.4L or 6.8L engine
• Ford is the first Original Equipment Manufacturer (OEM) to have a 2.5" hitch receiver for improved towing security with trailers over 12,500 lbs.
• 5th-wheel towing up to 24,600 lbs. on F-450 DRW, 18,800 lbs. on F-350 DRW with TowBoss Package
• Best-in-class(2) 33,000-lb. maximum Gross Combined Weight Rating (GCWR) (F-450 DRW)
(1) See the 2010 RV & Trailer Towing Guide, available as a printable PDF on eSourceBook, or the vehicle Owner’s Guide for additional towing information.
(2) Class is full-size pickup trucks over 8500 lbs. GVWR.
(3) Properly equipped.
NOTE: Please refer to the weight ratings in the Specifications section for additional model-specific ratings and information.
2010 Trailer Tow Guide https://www.fleet.ford.com/showroom/...10_default.asp
randy
Ford Fleet/Comm Truck Mngr. Custom F-650 Trucks, Shelby GT500 & KR Mustangs. 406 544-6891 [email protected] Thanks Randy
TDG Mafia #53 ... Riding High Club #30 https://www.thedieselgarage.com/foru...pictureid=1589
I'd rather be riding my motorcycle thinking about God, than in church thinking about my motorcycle. ~unknown~
"I wanna die like my grandfather, in his sleep, not like the other 4 passengers screaming in his car".
2008 Harley Softail Custom 105th Aniv Limited Edition
2006 Harley F-250 Black w/Blue Flames FOR SALE $23K
2006 Harley F-350 Tor Red w/Black Flames SOLD
2005 Harley F-250 True Blue w/Med Blue Flames SOLD
2004 Harley F-250 Black & DSG 2/tone 6" Lift SOLD
1.3 million miles OTR and still Truckin!!
If you can read this, thank a teacher. If it's in English, thank a soldier.
HARLEY6LF250SDU is offline
The Following 4 Users Say Thank You to HARLEY6LF250SDU For this addition to TDG:
barry1me (04-20-2011), crzycowboy (01-28-2010), jd87 (01-28-2010), Rcannon (01-28-2010)
post #8 of 46 (permalink) Old 01-28-2010, 05:55 AM
Hi,
I think there is only one difference between F250 & F350 is that the F350 has larger spacer under the rear leaf springs. And other options like springs and shocks, frame, body etc are same.
Tamadams is offline
post #9 of 46 (permalink) Old 01-28-2010, 09:25 AM
You all better do some research, especially you Randy.
You will find the axle thickness is different on the F-350 SRW..
Start by searching these forums...
Also folks, with larger spacer blocks comes different shocks..
2008 F-350
KEM 345 tuned.
My pics;
George C is offline
post #10 of 46 (permalink) Old 01-28-2010, 12:56 PM
There are more splines on the F350 SRW axle as well....
EKUgrad is offline
F250 rims on to F350 budman1239 General Ford Truck and Excursion 4 12-09-2007 12:18 AM
converting a f250 -f350 Orangepstroke 1994-2003 7.3L Power Stroke 17 11-27-2007 04:30 PM
F250/F350 BIG difference seven.three 1994-2003 7.3L Power Stroke 8 10-17-2007 03:53 AM
F250 vs F350 which to get. azdrt 2008-2010 6.4L Power Stroke 43 07-01-2007 09:33 AM
Difference between F250 and F350 SRW Excavator General Ford Truck and Excursion 12 09-19-2006 09:14 PM
