hey guys...just a thought...i do a lot of work for the local landscapers and ONE thing is RUN A GAS STABILIZER...the ethenol in the gas is terrible for a small engine...other things r rr gas filter in tank and replace the lines....about the carbs...replace them. this will keep u sane!!!!
Agreed I try not to fill any of my low use power equipment with summer gas. It is formulated differently in my area and turns to garbage in weeks. Most of the higher quality 2-stroke oils now have a stabilizer in them. I did find a gas station that had a special pump with 100% gasoline for boats and power equipment. Might fill up my cans there next time I go by.
Early 2004 F-250 4x4 CC 6.0
