What is it worth roughly - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 5 replies and been viewed 894 times.
post #1 of 6 (permalink) Old 07-17-2010, 07:36 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
I got offered a crank, head(complete i think maybe), bare block. I believe it is for 94-98 12v but could be 89-93 i will find out today hopefully. What are the dif between 89-93 and 94-98 on the block, crank, head???? He only wants $300 doesnt seem to bad tell me what you think.
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 6 (permalink) Old 07-17-2010, 10:04 PM
ADMIN/MAFIA
neeltburn's Avatar
Brandon, so many things "could" be wrong here. How much do you trust this guy. The block could be cracked the head could need work or be cracked. However if everything checks out and it is all in good shape I would think that is on heck of a deal. (hoping it came from a p-pumped 12v )
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 6 (permalink) Old 07-17-2010, 10:09 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
Well its a family friend who lost hope for a conversion so trust is not an issue lol he is alot bigger than. me so a beating if something is wrong will require lots of beer lol. So lets say its in good shape....hell of a deal then either way 300 bones seems cheap bu if its bare i guess that sounds better will no more tonight after i talk wit my uncle who is checking it out for me.
post #4 of 6 (permalink) Old 07-19-2010, 02:12 PM
PhilipR's Avatar
The blocks are essentially the same IIRC. The heads will all bolt on the bu the non-I/C motors uses a 9mm injector tip and the I/C'd motors use a 7mm tip injector.
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
SOOTBANDIT (07-19-2010)
post #5 of 6 (permalink) Old 07-19-2010, 06:24 PM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
So it is a 97 block head and crank. It is still an rotating assembly. Are these blocks sleeved or not? Cause my plans may have just changed to building a p-pumped motor instead. My uncle also found me a decent 89-90 Dodge D250 Reg cab no motor or rearend and no bed but has the 60 up front and an auto but i wil be running a manual more than likely and transfer case body is fair no major dents in bed or front clip for $800. Where does a person look for rebuild kits for the cummins might have to bore it a little def starting from scratch. Will know more as i get moved there and get the truck bought and pulled into the shop for the winter project
post #6 of 6 (permalink) Old 07-19-2010, 06:30 PM
PhilipR's Avatar
PM sent
-Phil-
PhilipR is offline
How much hp and tq, roughly with just a chip etc.. chief34 1994-2003 7.3L Power Stroke 6 01-24-2010 12:14 PM
What's this little guy worth? Duke 5.9L Cummins (Pre 1994) 6 02-03-2009 04:26 AM
what its worth powerstroke7.3 2003-2007 6.0L Power Stroke 6 01-30-2009 10:35 AM
Worth it? RILEYELIR General Diesel 2 03-22-2008 11:57 PM
what's a 95 worth D-Man 1994-2003 7.3L Power Stroke 1 02-02-2007 01:08 AM
