Dodge Steering Column - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bouncer, this thread has received 4 replies and been viewed 632 times.
post #1 of 5 (permalink) Old 08-12-2010, 03:17 AM Thread Starter
Administrator
Bouncer's Avatar
Anyone know what size and what type the little screw are that holds the two plastic pieces together around the column and the key switch? I had my steering column catch on fire and now I can barely turn the wheel due to all the wires around the clock spring coming apart. I need to get in there and get stuff fixed ASAP. Although I can not see what size/type they are and I need to purchase the tool to be able to get in there because the hole is so small.
Thanks!
1995 Dodge 2500 - just a wore out old farm truck
Bouncer is offline
post #2 of 5 (permalink) Old 08-12-2010, 07:10 AM
It is torex ( star ) #30 I think, to get the shroud off you need a screw driver - insert bits won't fit. Some of the screws are tamper resistant on a teardown. Most of the parts are common with the minivan.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 5 (permalink) Old 08-13-2010, 03:37 AM Thread Starter
Administrator
Bouncer's Avatar
Went by my Uncle's shop this afternoon and he had just what I needed. Turned out to be a #20 torx. Got the cover off and it is not good. Lot's of melted wire and insulation. In a way I wish it would have burnt, I would have stood back and watched. As it is though, the clock spring assembly definitely has to be replaced and we will go from there.
Thanks everyone!
Bouncer is offline
post #4 of 5 (permalink) Old 08-13-2010, 02:40 PM
Just grab the parts from a minivan, the ignition switch is usually melted to. Messy but not complicated. Under the dash spread the red butt splices as far as is convenient. The clock spring will usually reach.
keydl is offline
post #5 of 5 (permalink) Old 08-13-2010, 04:51 PM Thread Starter
Administrator
Bouncer's Avatar
Got it fixed today, took about two hours. The clock spring is a dealer only item for the 94-97 trucks and lists for $249. My dealer sold it to me for $199.20 + tax. The clock springs for the 98' up trucks can be had anywhere from $35-$65. I will post pics later of what it looked like when I got it out.
Bouncer is offline
Steering column pod 06f250sd Supporting Vendors Forum 0 03-13-2009 12:49 PM
LLY Steering Column Disassembled View (Column Shift Lean Shaft) ripmf666 GM Spec Info 0 12-28-2008 10:45 AM
LLY Steering Column Disassembled View (Column Shift Standard) ripmf666 GM Spec Info 0 12-28-2008 10:43 AM
steering column Cincinnati Guy 7.3L and 6.9 IDI (Pre 1994) 4 04-05-2008 04:20 PM
1st gen steering column 01duramax6spd Whats Been Sold 0 04-03-2008 11:28 PM
