Cab to axle on a 3500 crew cab dually - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wftree, this thread has received 4 replies and been viewed 6541 times.
post #1 of 5 (permalink) Old 09-17-2010, 08:26 PM Thread Starter
what does not kill you ..
I am looking at a crew cab dually and want to replace the bed with my aluminum flat bed but need to know the cab to axle measurement????
Thanks
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #2 of 5 (permalink) Old 10-13-2010, 02:13 AM
I know you said dually but you do know a cab and chassis are different. The dually will have the same wheel base as a pickup and use the pickup bed. A cab and chassis will be 6 inches longer wheel base and the frame rails will be a foot overall longer in lenght. But the cab and chassis will have a narrower rear end.
later is offline
post #3 of 5 (permalink) Old 10-13-2010, 02:10 PM
Administrator
fordt's Avatar
Images: 5
Thanks
Not sure what year you are talkin about, but I do know that a 2003 Dodge is 58" CA.
Since you mentioned you were going to take the bed off I assume that it is not a newer cab/chassis model.
Best way to figure it out, call any bed manufacturer, give them the year and make and they can tell you right away.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #4 of 5 (permalink) Old 10-14-2010, 06:12 PM Thread Starter
I am looking used and may end up with a pick up box although I am looking for a Cab Chassis. If I buy one with a box I would like to pull it off and install the Custom Aluminum one I have on my F450 right now
wftree is offline
post #5 of 5 (permalink) Old 10-15-2010, 12:11 PM
Administrator
fordt's Avatar
Images: 5
It could work with some modifications, as long as the CA measurement is the same or very close. If not, you would have the fenders off center, and possibly getting in to the tires.
-Wayne
fordt is offline
Plowing with crew cab 3500 longbox Duke Duramax 2006-2007(LBZ & LLY) 10 09-13-2010 01:05 PM
price for a 2000 6.5L crew cab single rear axle bigpapawack 6.5L Diesel Engine 25 02-27-2010 01:23 AM
Duramax in 87 3500 crew cab Kasprzak85 Diesel Conversion 8 05-08-2007 11:06 PM
95` dodge dually 3500 rear axle BogginF350 General Dodge Discussion 0 02-18-2006 12:46 AM
