Cooling your fuel before injection - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 26 replies and been viewed 2893 times.
post #1 of 27 (permalink) Old 10-15-2010, 06:38 AM Thread Starter
BlowinSmoke's Avatar
Is cooling your fuel a possibility? Like adding a mod before its injected?
BlowinSmoke is offline
post #2 of 27 (permalink) Old 10-15-2010, 07:07 AM
hayjayhorses's Avatar
I like my fuel warm in the winter. From what I under stand 203* is the best temp for #2 to be injected, I thing dieselsite.com talks about it whaen you read about the 203* thermostat.
the Duramax's have a fuel cooler on the return line going back to the tank.
I know the guy's runing gassers want cold fuel
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #3 of 27 (permalink) Old 10-15-2010, 08:23 AM
7.3 addict
warm diesel atomizes better making for more efficient fuel burn which equals better economy. gas has a tendency to ignite (IE: detonate) when warm.
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #4 of 27 (permalink) Old 10-15-2010, 08:58 AM Thread Starter
So why would heavy equipment run inline fuel coolers? I was told from a shop it adds a little more horse. And doesnt compression heat up the air in the cylinder more than it already is?
post #5 of 27 (permalink) Old 10-16-2010, 08:29 PM
Putting on a return line fuel cooler, is a good idea. I have a LMM GMC and it has a return line cooler. Fuel above 147 degrees I believe looses power with any amount above that from memory I believe it is 1% for every 4 degrees.
Just a thought!
Johnp3 is offline
post #6 of 27 (permalink) Old 10-16-2010, 09:34 PM
You do not want to be too hot or cold, you can boil the fuel and not be able to pump it and diesel can jell or become solid when it is too cool.
later is offline
post #7 of 27 (permalink) Old 10-17-2010, 03:53 AM
what is the boiling point of ULS diesel at sea level?
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #8 of 27 (permalink) Old 10-17-2010, 04:29 AM Thread Starter
Why would a heavy crane tech say that having cooler fuel increases horse power a bit?
post #9 of 27 (permalink) Old 10-17-2010, 08:17 PM
The cooler the fuel the more energy there is available in the same volume. Go to a truck stop and feel the tempature of the fuel tanks.
A lot of heavy equipment use a day tank that has a smaller volume than the main tank and a separate pump that on a float fills the day tank when it gets low. Lots of equipment has this set up, and the day tank fuel will get warm enough to vent white smoke. Putting on a fuel cooler will lower the fuel tempature to the ambient tempature.
It is a good way to get extra power on a class eight. or any engine that runs a lot of fuel return.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
BlowinSmoke (10-18-2010)
post #10 of 27 (permalink) Old 10-18-2010, 05:07 AM Thread Starter
That makes more sense now that I read that twice. So on our dinky engines compared to them its a nice thought but has no practical application.
LLY Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:38 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 2 ripmf666 GM Spec Info 0 12-28-2008 11:37 AM
LLY: Fuel Injection Fuel Rail Assembly Replacement - Bank 1 ripmf666 GM Spec Info 0 12-28-2008 11:24 AM
12V fuel injection lines ash_flat_diesel Whats Been Sold 0 12-25-2007 04:50 PM
Fuel in cooling system 444E imported_Prodiesel Medium and Heavy Duty 19 03-18-2007 06:11 PM
