Gear oil leaking out rear hub - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 6 replies and been viewed 3894 times.
post #1 of 7 (permalink) Old 10-16-2010, 12:47 PM Thread Starter
BlowinSmoke's Avatar
More inquisitive post than anything really. Read other articles and posts on rear hub service. But many wondering what its actually leaking out of.
Are the nuts just loose and its leaking out the cover? or does that axle (Dana 70) slide inside the spindle?
Thanks for satisfying curiousity before I tear things apart, even though thats really how I'm going to find out
BlowinSmoke is offline
post #2 of 7 (permalink) Old 11-16-2010, 05:53 PM
bmoeller's Avatar
The cover on the rear of the rear axle diff can come loose and leak, or the gasket/RTV silicone is dried out.
The Dana 70 REAR axle shaft is a full floating axle (Axle shaft transmits power ONLY. Does NOT carry ANY weight from the vehicle.) The axle flange ("cover" as you put it) is a part of the axle shaft its self. Not a separate piece.
In this case, there is a gasket or RTV silicone where the axle flange is bolted to the axle hub and then there is a oil seal that can leak on the back side of the wheel hub.
GM does/has use/d full floating axle shafts that have a cap on the hub. The shaft is splined and slips into the diff, and on the other end it has teeth (looks like a chain sprocket of sorts) and the hub end accepts the teeth. Still has a gasket and oil seal setup like the Dana.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 7 (permalink) Old 11-24-2010, 02:05 PM Thread Starter
Thanks.
post #4 of 7 (permalink) Old 05-12-2011, 10:50 PM
what size in the nut on the hub cause mine is leaking of the oil seal
chevyboy3672 is offline
post #5 of 7 (permalink) Old 05-13-2011, 06:11 PM Thread Starter
If no one else replies before I do, I'm at work at the moment but I'll check my socket size when I get home for you.
post #6 of 7 (permalink) Old 05-13-2011, 06:59 PM
thank you
post #7 of 7 (permalink) Old 05-16-2011, 05:38 AM Thread Starter
Sorry it took so long out of town family emergency. If you havent found it yet though what I used for mine was a 2-1/2" hex socket
steering gear leaking and trans lines expletive0 Duramax 2006-2007(LBZ & LLY) 7 02-26-2009 11:06 AM
Rear End Leaking imported_Stroker01 1994-2003 7.3L Power Stroke 1 03-26-2008 03:03 AM
gear lube leaking bmxdirtjumper13 1994-2003 7.3L Power Stroke 0 04-23-2007 11:00 PM
leaking rear end got a few ?'s I10HaulR 2003-2007 6.0L Power Stroke 7 06-30-2006 04:33 AM
Rear End Leaking? fordt 2003-2007 6.0L Power Stroke 11 12-17-2005 12:17 AM
