1998 dodge 1500 rear end howling - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by geok, this thread has received 3 replies and been viewed 1985 times.
post #1 of 4 (permalink) Old 11-27-2010, 12:45 AM Thread Starter
Have a 1998 dodge 1500 that the rear end sounds like I have a pair of mud grip tires on it. Truck has 164K miles on it but rear end seem very tight for one with that many miles. Jack one wheel off the ground and wheel does not rock back and forth much when in park.
geok is offline
post #2 of 4 (permalink) Old 11-27-2010, 05:22 PM
BlowinSmoke's Avatar
At what times is it howling?
BlowinSmoke is offline
post #3 of 4 (permalink) Old 11-29-2010, 02:27 AM Thread Starter
Most all the time. When I give it gas or coasting. Only time it doesn't make any noise is when I am going down hill and give it just enough gas that the rear end is not pushing the engine.
geok is offline
post #4 of 4 (permalink) Old 11-29-2010, 09:27 PM
TDG Mafia
Jeffybuilt's Avatar
I have a '97 1/2 ton that does the same thing. Dad changed the rear end fluid out and replaced it with regular 80/90, and did not put any limited slip additive in, and ever since, it has howled just like you say.
After he informed me of this, I drained the rear end and cleaned out a lot of metal shavings, and put in the proper fluid. It has quieted down a little since then, but still there. Not saying that is your issue, but thats all I can think of from experience. If you have a limited slip diff in that truck, I believe there should be a metal tag of sorts attached to one of the bolts/bolt holes.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
98 Dodge 1500 may get a 4BT geok General Dodge Discussion 0 04-25-2010 12:59 PM
rear end 1998 dodge 2500 dana 70 3.54 gears ash_flat_diesel Dodge Parts 0 08-30-2009 03:09 PM
1997 Dodge Ram 1500 Deezle1 Whats Been Sold 0 10-06-2007 08:33 PM
97 dodge ram 1500 transmission Deezle1 General Gas Vehicle 2 09-06-2007 01:23 PM
1998.5 Dodge sdhDIESEL Whats Been Sold 0 04-11-2007 12:23 AM
