Help understanding a points ignition system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 14 replies and been viewed 1357 times.
post #1 of 15 (permalink) Old 12-03-2010, 03:30 PM Thread Starter
I am planning to convert my old Dodge D200 to an electronic ignition. But for right now I have to get the truck back on the road so I can get to work. The truck all of a sudden died and would not start. When I pulled the cap there was a lot of moisture. It needed it anyway so I went ahead and tuned the truck up with new plugs, wires, cap, and rotor. But the truck still would not start and the plugs were not getting any spark. I looked it up and everything pointed to the points being bad. So, I cleaned the cam and filed the points to a smooth solid contact. I tried to buy a new condenser but there were a lot of issues with that so I said to hell with it. Further research stated I need a dwell meter to make it all work. I just need this truck to run for now. Is there another way I can do this without buying an expensive dwell meter I am only going to use once?
post #2 of 15 (permalink) Old 12-03-2010, 05:51 PM
gone fishin!
you should be able to clean the points and replace the condenser....... also may want to get a new coil and put it on there........
what issues are you having with getting a new condenser?
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 15 (permalink) Old 12-03-2010, 05:57 PM Thread Starter
I got that part sorted out now. But the parts store had a hard time locating the correct one. The points do look good now that I filed them.
post #4 of 15 (permalink) Old 12-03-2010, 10:25 PM
gone fishin!
if you have clean adjusted points, a new condenser, new cap and rotor.... but still no spark than i would say its coil or advance box if it has one.
post #5 of 15 (permalink) Old 12-04-2010, 12:55 PM Thread Starter
Thanks, I will check them next.
post #6 of 15 (permalink) Old 12-04-2010, 01:32 PM
Dodgefarmer's Avatar
What year is your D200?
Could be the resister is burnt out in the powered wire going to the coil. Check for voltage on both sides or temperary use a jumper wire to bypass the resister and see if you get spark. Dont run it with the bypass except to see if thats the problem otherwise you can fry a good coil.
singles club # 198
Dodgefarmer is offline
floridaboy (12-04-2010)
post #7 of 15 (permalink) Old 12-04-2010, 08:26 PM
gone fishin!
i forgot about that..........
post #8 of 15 (permalink) Old 12-04-2010, 11:12 PM
Banned
Bad ballast resister or fuseable link.
wastedwagesracing is offline
post #9 of 15 (permalink) Old 12-05-2010, 01:16 AM Thread Starter
Dammit, could it really have been that simple? I am going to be angry if that turns out to be the issue.
post #10 of 15 (permalink) Old 12-05-2010, 03:04 AM
Don't feel bad. I learned the hard way.:
singles club # 198
points system RacerX Site Information 35 09-04-2006 11:12 PM
The Points System Issues NMU98 The Parking Lot 30 04-02-2006 11:25 PM
The points system Motown Fire Site Information 9 03-31-2006 11:45 PM
