FIRST DIESEL LOTS OF ?s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by possiblexgasser, this thread has received 4 replies and been viewed 858 times.
post #1 of 5 (permalink) Old 01-02-2011, 02:34 PM Thread Starter
possiblexgasser's Avatar
Smile FIRST DIESEL LOTS OF ?s
I recently bought a 97 2500 with a as far as i know all stock 12valve with 190,000 miles would like to play with it a little without sacrificeing dependability or durability its primary use will be plowing snow and towing oh yeah live in minnesota so needs to still run in -30 lol any advice will be greatly appriceated !!
possiblexgasser is offline
post #2 of 5 (permalink) Old 01-03-2011, 01:54 AM
If it has a P7100 injection pump it is a truly great motor and if you leave it alone it will outlast the truck. Change the oil, and fuel filter regularly and flush the cooling system every five years. Do a valve set every 2 years.
play with it and it will let you down.
Johnp3 is offline
post #3 of 5 (permalink) Old 01-12-2011, 03:13 AM
Keep track of the front wheel bearings, the time from malfunction to expensive failure is short. If it is an automatic it needs a transmission temperature gauge, a boost gauge is a good plan. Before doing anything to the fuel system you need a pyrometer.
One of the things to do is to cure the KDP and torque the case bolts on the timing cover and cam retainer.
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 5 (permalink) Old 01-18-2011, 02:05 AM
Can anyone tell me where the computer is on a 96 2500 dodge diesel. Have a problem. My generator light, check engine light, wait to start light, water in fuel light flicker on and off and on. When this happens my tac jumps back in forth. Does not effect the way the truck runs. Just realy anoying. Thinking it may be loose connections. Anybody had this problem ?
Charlie Janek is offline
post #5 of 5 (permalink) Old 01-18-2011, 05:54 AM
Look under the plastic on the curb side top of the firewall. Symptoms sound like a corroded ground connection - never had to look it up. One of the 'tuneup' things to do is to service all of the grounds with a Dremel, SS brush and grease or anti-seize. Make all parts shinny and protect from corrosion.
keydl is offline
using lots of oil Stroker99 1994-2003 7.3L Power Stroke 4 01-31-2010 05:13 PM
Lots of truth here tjl The Parking Lot 4 10-16-2009 07:38 PM
2003 Ford F-250 6.0 Powerstroke diesel lots of mods - $22000 SparkyLV Whats Been Sold 19 01-05-2009 09:48 PM
FS: 2006 Quad Cab 4x4 Cummins Turbo Diesel! (lots of big pictures) DodgeZ Whats Been Sold 6 03-03-2008 03:11 PM
Here they come and lots of em.. Lowboy Medium and Heavy Duty 4 02-28-2007 01:06 AM
