I need some learning on the Dodge overdrive transmissions. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 4 replies and been viewed 930 times.
post #1 of 5 (permalink) Old 01-07-2011, 08:56 PM Thread Starter
I have a 1972 D200 with a 318 727 auto and a D60 with 4:10 gears. I would like to slide in an overdrive tranny in place of the 727. My issue is I know less than zero about Mopar trannies. Can someone enlighten my on what is out there and what would work with my application? Also, is there a good auto tranny out there by Mopar that is not electronic?
post #2 of 5 (permalink) Old 01-08-2011, 05:09 AM
All the OD trans use electric solenoids for OD and lockup converter.
The gasser trucks normaly used the 518 family of trans. It can be found as a nonlock converter or a lockup. It just depends on the year.
For an OD trans look in the early 90's trucks. To tell the trans you want. Look by the rear trans cooler line. There is a wiring plug facing upwards towards the floor pan. If that plug is two wire. That mean OD trans. If it is a 3 wire plug. That means OD and lockup converter. If the trans has more than 3 wires in that plug. Walk away from it.
Now on the gassers. A 360 C.I. engine is an external balanced engine. A 318 C.I is a internal balanced engine. They use different converters. So be carefull there.
Philip is offline
post #3 of 5 (permalink) Old 01-08-2011, 03:03 PM Thread Starter
There is a lot to laern on these old Mopars I see. What do you mena by C.I.?
post #4 of 5 (permalink) Old 01-12-2011, 12:29 AM
Dodgefarmer's Avatar
cubic inch
singles club # 198
Dodgefarmer is offline
post #5 of 5 (permalink) Old 01-12-2011, 04:44 PM Thread Starter
Ugh. I guess the obvious is sometimes a little too obvious.
WHat comes in the 3/4 and one ton trucks?
At least he is learning to read Lonesome7.3 The Parking Lot 17 05-14-2009 05:38 AM
Learning how to drive. Elwood 7.3L and 6.9 IDI (Pre 1994) 2 02-18-2009 01:18 AM
Still Learning imported_06F450 2003-2007 6.0L Power Stroke 6 09-13-2007 12:04 PM
Learning at the track Snake General Ford Truck and Excursion 3 09-15-2005 05:09 PM
Transmission learning? heinzboy 2003-2007 6.0L Power Stroke 11 08-21-2005 02:50 AM
