5.9 Gas AKA 360 T-stat - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 7 replies and been viewed 1176 times.
post #1 of 8 (permalink) Old 02-21-2011, 03:12 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Guys,
T-Stat housing is leaking on my Dad's truck..
It is a 2002 Dodge Ram 1500 5.9L Gas 4WD QCSB. It also has 3.90 gears
I can see coolant running residue around the T-Stat housing and down the front of the block.. The Degas bottle on top seems to empty out slowing, so beside replacing the T-Stat and Housing, what else can I do to check to make sure that is all of the problem? I really done want to pull the intake!
Also for those that have done a T-Stat do you have any tips?
Thanks!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 8 (permalink) Old 02-23-2011, 12:04 AM
i know on my older 97 gas burner 360 the intake was two piece and there is a gasket between the lower and upper that after awhile goes bad makes for some vacumn issues my dads 00 model had both the upper intake gasket and the bottom one go out on him at a little after 100,000 miles
04 Dodge 4x4 crew cab 6sp valair kevlar/ceramic clutch stage 1 industrial injectors superphat shaft 62 turbo hot juice with attitude ats arc flow 5in exhaust isspro ev2 gauges and 150 airdog soon to come studs intercooler not sure after that
01 ex cab powerstroke 4x4 diablo programmer autometer gauges str8t pipe and i think the oil pump is dead b/c it wont start and im getting fuel
silverpeteok is offline
post #3 of 8 (permalink) Old 02-24-2011, 02:24 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
I can see coolant on top of the intake around the TStat so thats where im gonna start. Truck only has 89k on it. hopefulle this will fix it.
Sent from my iPhone using Tapatalk
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #4 of 8 (permalink) Old 02-25-2011, 10:45 PM
the intake gasket is the only problem ive had with mine its got 200 plus thousand on it just using for a all purpose beater truck but still does its job only been through one tranny to
post #5 of 8 (permalink) Old 02-26-2011, 02:58 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Did you replace the intake gasket your self?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 8 (permalink) Old 02-26-2011, 05:10 PM
me and my dad did it in his shop it wasn't that hard just time consuming you should set a 8 hour day aside if your going to do it mine didn't take that long but its nice to not be rushed
post #7 of 8 (permalink) Old 02-26-2011, 06:27 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Do habe have to pull the alternator to get the the tstat housing off?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 8 (permalink) Old 02-27-2011, 03:54 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Well, its been done for about 2 1/2 hrs now, no more antifreeze smell. The T=Stat gasket ( well what was left of it) was shot. no wonder it wasn't leaking worse. Gonna decrease the engine tomorrow after work with some engine bright.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
Is my T-stat going bad? 99fordtruckguy 1994-2003 7.3L Power Stroke 4 12-03-2009 04:54 AM
203* t stat for 7.3 psd camojeeper Whats Been Sold 2 01-20-2009 05:00 PM
203 degree stat Houndy 1994-2003 7.3L Power Stroke 4 05-01-2008 05:55 PM
T-Stat replacement 4cstr Dodge - Modification instructions, Product installs and Tech Articles 0 12-19-2005 08:17 AM
