Check Engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kickermatt, this thread has received 2 replies and been viewed 1644 times.
post #1 of 3 (permalink) Old 03-19-2011, 07:35 PM Thread Starter
Cummins
kickermatt's Avatar
Check Engine light
i have a 99 dodge ram 1500 with the 318. my 'check Engine' Light turns on and off. i dont understand, it came on the code said the rear o2 senser. its been on for a couple days now, and my truck is running fine... the the light turned off and it only comes on once in a while.... whats wrong with it?
kickermatt is offline
post #2 of 3 (permalink) Old 05-17-2011, 06:11 AM
Check wires on the rear o2. Being exposed to the elements there could be a bad wire. Or maybe the rear o2 is starting to go bad. If the wires are fine and the check engine bothers you I would have the code cleared unless you want to spend money on a sensor.
Mack359 is offline
post #3 of 3 (permalink) Old 05-17-2011, 05:49 PM
ADMIN/MAFIA
neeltburn's Avatar
Check to make sure you are not getting moisture in the sensor connection. Your 02 sensor could be failing, but I would check the connection first before spending money.
Also I moved this to the General Dodge Section since it does not relate to a Cummins Engine. I have a 24 hr redirect setup as well.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
check engine light 03ford 2003-2007 6.0L Power Stroke 0 10-07-2007 12:02 AM
check engine light....on then off? imported_ryan 1994-2003 7.3L Power Stroke 4 08-25-2007 01:54 PM
check engine light 2blue11 5.9L Cummins (2003-2007.5) 3 05-21-2007 12:39 AM
check engine light RebelBullrider 6.7L Cummins (2007.5-2011) 2 05-18-2007 03:42 AM
