Input on rebuilding my 727 stronger - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 0 replies and been viewed 724 times.
post #1 of 1 (permalink) Old 05-03-2011, 01:08 AM Thread Starter
Before I dump a bunch of money on converting my old Dodge D200 to an over drive 518 I wanted to compare the pricing pros to just rebuilding my 727. I have priced several stock rebuild kits but I would like to know what all is out there to beef it up. The reason mine is shut down is because I lost reverse. When I dropped the pan big metal chunks fells out. I have read this is a common problem. How do I prevent it from happening again? What kind of upgrades should I look into? This is in a ton truck that although is babied does get used as a ton truck. I do pull trailers and I do haul hay and other stuff. So I want a transmission that can handle being worked. What kind of torque converter should I look for? What kind of shift kit do I need? Stuff like this is what I would like to learn about before jumping into a conversion that might not be the best way to go for this truck.
Rebuilding The 6.0 Mundy351 2003-2007 6.0L Power Stroke 1 03-15-2010 02:00 AM
rebuilding a 7.3 ps 4x4ford 1994-2003 7.3L Power Stroke 1 03-12-2007 05:25 PM
Do they make stronger leave springs like on a f=450 I10HaulR 5.9L Cummins (2003-2007.5) 3 06-14-2006 02:40 AM
Stronger yoke at T case gong to front? gtspowerstroke General Ford Truck and Excursion 9 05-15-2006 12:35 PM
who makes a stronger clutch for an 05??? TANK'S 250 2003-2007 6.0L Power Stroke 4 02-12-2006 07:16 PM
