Found a motor home with a Mopar big block and I have some questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 24 replies and been viewed 2747 times.
post #1 of 25 (permalink) Old 06-01-2011, 09:47 AM Thread Starter
I was in a motor home in a salvage yard and found a Mopar big block under the engine cover. It looks great and is complete. However I know very little about this sort of thing. I am new to the world of Mopar. I am hoping to go out there today with the camera but in the mean time can anyone tell me anything about them. I think the Motor home is a 72 and it looks like it has a 727 behind the engine. Getting it out looks like it will be quite an under taking. Considering I just want to put this engine on a stand in hopes I will get a project vehicle later for it what would be a good price for it? How can I tell if it is a 440 or a 413? If it is a 413 what are the pros and cons of running it? If I get it, it will most likely go in a big truck build later on. I have always wanted a classic Dodge truck or SUV sitting tall with big block power and shining like a new penny.
post #2 of 25 (permalink) Old 06-01-2011, 11:23 AM
plainredtruck's Avatar
Images: 11
I don't know the answer to your questions, but I know where there's a fresh 440 with a fresh 727 in a motor home that you could have for fairly cheap.
PM me if you want details.
Wish I could help on the ID.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 25 (permalink) Old 06-01-2011, 04:46 PM Thread Starter
I might be interested. I will get with you after I check this one out.
post #4 of 25 (permalink) Old 06-01-2011, 07:06 PM
Images: 11
BTW,
Happy Birthday!
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 25 (permalink) Old 06-01-2011, 08:15 PM
Nadir's Avatar
It's going to be a low compression cast crank engine and the 727 (maybe an early 518 if somebody swapped it in) will be a 4-pinion planetary with the part throttle valve body. All good, especially if you build the engine for higher compression. The cast cranks can live around 500hp.
Truck Pics:
Nadir is offline
post #6 of 25 (permalink) Old 06-01-2011, 08:18 PM Thread Starter
Thanks man. I was hoping to get a Mopar big block for myself.
post #7 of 25 (permalink) Old 06-01-2011, 08:19 PM Thread Starter
We posted at the same time. Do you think I can get 500 out of a 413 if that is what it turns out to be?
post #8 of 25 (permalink) Old 06-01-2011, 08:30 PM
Nadir's Avatar
It's not likely to be a 413 if it's a '72. The last 413s were installed sometime in the mid-60s.
Truck Pics:
Nadir is offline
post #9 of 25 (permalink) Old 06-01-2011, 08:48 PM Thread Starter
Even if I am wrong on the year, I am not that far off. Then this is not a 413. Hopefully it is a 440. I do not know much about them but I do know the aftermarket supports it.
post #10 of 25 (permalink) Old 06-10-2011, 07:41 PM
Look by in front of the left cylinder head. By the intake rail is a small square machined pad. The engine size will be stamped there.
If that is a class A motor home. Most likely a 413.
No way its a 518. Dodge never made the 518 for a big block engine. The 518 came out almost a decade after the big blocks went out of production.
Philip is offline
Found a great home stereo drgriff The Parking Lot 3 02-28-2010 04:56 AM
Found a 1 yr. old 3500 Chassis/Cab leftover, questions M1A 6.7L Cummins (2007.5-2011) 15 01-22-2008 02:44 AM
EGR Block off questions- why do it? 05PSDV8 2003-2007 6.0L Power Stroke 5 01-03-2008 11:38 AM
motor block StrokerDude 1994-2003 7.3L Power Stroke 8 11-29-2007 07:40 PM
brmpipes found new home brmpipes Introductions 8 11-29-2006 09:42 PM
