Torque converter questions and selection help. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 2 replies and been viewed 860 times.
post #1 of 3 (permalink) Old 10-17-2011, 08:04 PM Thread Starter
I think I have narrowed down the transmission I want for my 72 D200 with a 318. Because it is a ton truck and we do plan to use it as such I want a good transmission in it that will not fail on me like the tired stock one. Now my attention is on the torque converter. I know very little about automatics and even less about Mopar anything. So first question:
What does lock up mean when dealing with torque converters?
What is stall speed and how do I know what mine is?
This truck has a 318 with 4:10 gears stuffed in the rear D60 what role does that information play in selecting the torque converter?
This is the link to the trans I am 90% certain I am getting.
http://www.summitracing.com/parts/TC...n/?prefilter=1
This is the torque converter TCI said I need.
http://www.summitracing.com/parts/TCI-142240/
What would happen if I used my stock original Torque converter? Other than voiding the warranty from TCI could I hurt anything else? Also, how do I know if anything is wrong with it to begin with?
If the new Torque Convert does not have a drain plug, can I simply drill and tap the house to install one?
Any input on what I have put out there so far?
post #2 of 3 (permalink) Old 10-22-2011, 04:02 PM
Never reuse an old converter. There is to big of a chance of that bitting you big time.
Philip is offline
post #3 of 3 (permalink) Old 10-22-2011, 09:51 PM Thread Starter
I agree, I have found a good replacement locally.
torque converter questions Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 4 10-26-2009 06:16 AM
torque converter... gon2sea 5.9L Cummins (Pre 1994) 1 02-25-2008 02:03 PM
Torque converter ? Yellow Yota 5.9L Cummins 12 Valve (1994-1998.5) 4 02-07-2008 03:42 AM
Torque Converter... Cummins_Beast 1994-2003 7.3L Power Stroke 5 11-04-2007 01:11 AM
a few questions about turbo selection pwrstroke99 1994-2003 7.3L Power Stroke 10 12-07-2006 11:49 PM
