Routing transmission cooler line questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 5 replies and been viewed 2556 times.
post #1 of 6 (permalink) Old 03-17-2012, 11:00 PM Thread Starter
I am installing an external transmission cooler on my 727 equipped D200. The factory lines run to the radiator and back to the tranny. Is it better have the fluid run through the external cooler first then through the radiator or the other way around?
post #2 of 6 (permalink) Old 03-18-2012, 05:02 AM
2wpuller's Avatar
you can do it either way dosn't make any difference on how much it cools the fluid.
Dale
1975 f250 6.0Perkins,twins,6sp allison.HM.airride,4"ex,Airtilt front clip.
72 chevy 5.9 5sp.
2007 Dodge 2 WD pulling truck
Sponsors
GoerendTransmission
Haisley Machine
MCS MidwestPerformanceDiesel
ShowMePerformance
[/FONT]
2wpuller is offline
post #3 of 6 (permalink) Old 03-18-2012, 02:57 PM
Nadir's Avatar
If I was only interested in "cooling" the fluid," I would eliminate the shared radiator unit altogether.
Truck Pics:
Nadir is offline
post #4 of 6 (permalink) Old 03-18-2012, 05:15 PM Thread Starter
Dosen't the rad cooler help heat it up during the winter? That is also why I am wondering if there is a diffference when routing the lines. I was thinking if I run it through the cooler first it might heat up a little bit when it hits the rad.
post #5 of 6 (permalink) Old 03-19-2012, 01:00 AM
Nadir's Avatar
There is a heat exchanger built into the side of the engine block for that purpose.
Truck Pics:
Nadir is offline
post #6 of 6 (permalink) Old 03-19-2012, 01:05 AM Thread Starter
Oh, I was wondering what that was. I just posted something about that, I noticed it while I was under the donor truck tracing the tranny lines.
Transmission Line Pressure dayusex 2003-2007 6.0L Power Stroke 5 08-17-2009 01:57 AM
How do I remove the trans. cooler line check balls? jcw74801 5.9L Cummins 12 Valve (1994-1998.5) 2 05-02-2009 06:04 AM
LB7 01 Fuel Injection Line Routing Diagram ripmf666 GM Spec Info 0 12-28-2008 09:36 AM
Tranny Cooler Line ????? cumminspride Duramax 2001-2004 (LB7) 11 12-03-2007 10:14 AM
4R100 cooler line routing adrianspeeder 1994-2003 7.3L Power Stroke 11 03-10-2006 01:45 PM
