Daully to Single - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 8 replies and been viewed 1080 times.
post #1 of 9 (permalink) Old 01-03-2013, 11:43 PM Thread Starter
BlowinSmoke's Avatar
Daully to Single
Is it easy or possible to convert a dually to a single rear wheel truck?
BlowinSmoke is offline
post #2 of 9 (permalink) Old 01-09-2013, 11:29 PM
Yes, change the Bed, change the rear axle, change the wheels, change the front hub's. What did I forget? Around here singles sell for less.
later is offline
post #3 of 9 (permalink) Old 01-10-2013, 01:22 AM Thread Starter
What is your, "around here"?
post #4 of 9 (permalink) Old 01-11-2013, 01:27 AM
West Texas, with the oil field work increasing some of the welders are buying good old truck, usually dually and dropping a welder and tool in the back and going to work. Personally I would prefer a Cab-and-chassie with a welding bed.
If you are looking for a well built 3/4 ton contact Buck2.
later is offline
post #5 of 9 (permalink) Old 01-11-2013, 11:40 PM Thread Starter
I would prefer a one ton but as far as the beds go, what is a good retailer?
post #6 of 9 (permalink) Old 01-12-2013, 02:13 AM
First most cab-and-chassie's are 1 ton or larger. But where a dually has a 96 inch wide rear track outside a cab & chassie is 80 inches. But the frame is usually a odd length.
Next if you have a reasonable welding skills just build the bed yourself. If you are in a bigger hurry CM is a common brand. But if you are trying to work as a rig welder and you can not build your own bed, well what kind of advertisement is that? A common remark when you ask how good of a welder is will be " I built this truck".
later is offline
post #7 of 9 (permalink) Old 01-23-2013, 02:27 AM Thread Starter
Gotcha. Well not a welder by trade or in free time. But I have wanted to get one and have one mounted in the bed, so I guess that would be a bad***** place to start
post #8 of 9 (permalink) Old 01-24-2013, 01:28 AM
Do you have any Idea's as to what you will want it to look like?
later is offline
post #9 of 9 (permalink) Old 01-26-2013, 12:47 AM Thread Starter
Unfortunately not a clue.
2011 ford f-350 6.7 Daully lift tires jjjoetheplumber 2011+ 6.7L Power Stroke Diesel 13 07-31-2011 04:01 AM
single guy RussK The Parking Lot 1 02-04-2009 01:44 AM
6.4L Exhaust 4" single/Dual and Single 5" dfuser Supporting Vendors Forum 0 07-09-2007 03:25 AM
99 f-250 single cab chosen1 Whats Been Sold 2 04-23-2007 03:31 AM
Daully conversion StrokerAce 5.9L Cummins (Pre 1994) 7 01-26-2006 09:54 PM
