Speedo quit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RWS31, this thread has received 10 replies and been viewed 1633 times.
post #1 of 11 (permalink) Old 09-24-2009, 10:29 PM Thread Starter
RWS31's Avatar
Speedo quit
Went to leave work this morning and noticed that my speedo was not working and my ABS light and the BRAKE light were both lit up. Later the CHECK ENGINE light came on. Thinking it might be the speedo sensor in the trans, anybody ever seen this before? 2000 1500 4x4 318. Any help would be appreciated.
1999 4700 Started life as a reg chassis, then got dropped 4 inches and then raised 6 inches and 4X4 added and now in the Med duty 4X4 club.
Marmon Herrington 8000lb front axle and transfer case
TS Box
385/65/22.5 Goodyears on 22.5X12.25 Alcoas
Custom bed in the works
RWS31 is offline
post #2 of 11 (permalink) Old 09-25-2009, 01:52 AM
TDG Mafia
Jeffybuilt's Avatar
Originally Posted by RWS31 View Post
Thinking it might be the speedo sensor in the trans.
Yes, although I have not seen it throw a CEL...but that was on my 2500. Sometimes (not always) the sensor in the trans gets covered in small metal shavings, as it is magnetic. Before you replace it, try pulling it and cleaning the metal off first. You may need to clear the codes since it set a CEL, but often times (again, from my experience with the RWL speed sensor on the 3/4 ton) the BRAKE and ABS lights should go off after driving a short distance.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 11 (permalink) Old 09-25-2009, 04:11 AM
4play's Avatar
what he said above, but i am not sure about the 1/2 tons, if it has a sensor right in the top of the rear axle then that is probable the speed sensor for the speedo and ABS. usually the sensor in the trans is just for the trans shift op.
4play is offline
post #4 of 11 (permalink) Old 09-25-2009, 04:19 AM
TDG Mafia
Jeffybuilt's Avatar
Yea, I have a 1997 1/2 ton in addition to the Cummins, and the 1/2 ton dose not have a sensor in the rear end. I dont know about the newer one, like his 2000, but my 1/2ton only has the trans one. When the BRAKE and ABS lights were on in the 2500, it was my rear end speed sensor, like you said. Humm, let us know what you find out!
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #5 of 11 (permalink) Old 09-25-2009, 09:43 AM Thread Starter
RWS31's Avatar
Thanks for the info. I read somewhere else that the sensor in the rear axle is most likely the cause. Will pick one up today and post the results.
TS Box
RWS31 is offline
post #6 of 11 (permalink) Old 09-28-2009, 10:29 PM Thread Starter
RWS31's Avatar
Bingo, that was the problem. Replaced the sensor on top of the rear diff and all the lights went out and the speedo is working. Gosh I love the internet.
TS Box
RWS31 is offline
post #7 of 11 (permalink) Old 09-30-2009, 06:21 AM
4play's Avatar
4play is offline
post #8 of 11 (permalink) Old 10-09-2009, 02:04 PM
SIXINAROWMAKES'EMGO
yoder519's Avatar
how much did that run you i fyou don tmind em askin. di dyou buy it at the dealership
07 Chevy 2500HD 4wd RCLB (FOR SALE)
95 Toyota on 37s
SOLD-98 ECSB 24V
yoder519 is offline
post #9 of 11 (permalink) Old 10-09-2009, 04:20 PM
Ton Or None's Avatar
My ABS and brake light are on but my speedo works do you think that the sensor in the rear end is the problem?
1997 12V 3500 XCab Long Box Dually , 4'' down pipe, 5'' dual stacks, 100 plate, AFC FF, Gov springs tightened for now, HTS Trans, BHAF, 35'' tires with Alcoa wheels, 5'' lift, train horns.
Ton Or None is offline
post #10 of 11 (permalink) Old 10-09-2009, 05:34 PM
PhilipR's Avatar
There is a good chance it is...I would pull it and clean it in your case. I think they are around 30-40 new from Napa.
-Phil-
PhilipR is offline
Quit dipping Diesel Dog The Parking Lot 57 03-26-2009 10:02 AM
AC quit at 30k crosstx General Ford Truck and Excursion 4 01-19-2009 10:50 PM
want to quit my job RussK The Parking Lot 39 01-08-2009 10:51 PM
A/C quit working NCR 2003-2007 6.0L Power Stroke 4 03-20-2007 02:29 PM
I quit!!!! LargeCar The Parking Lot 3 10-27-2006 04:17 AM
