Lights and ac probs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Haus720, this thread has received 2 replies and been viewed 824 times.
post #1 of 3 (permalink) Old 10-13-2009, 01:49 AM Thread Starter
Lights and ac probs
Im sure the ac issue has to be somewhere on this sight. First i had no air coming out of vents at all. took to dealer and they claim i have a hole in box somewhere, sorry cant get part right now to fix and when we can it gona be 1800 to fix. OUCH, did some research on net checkd my doors and the door for outside to inside air was broke off and blocking both ways. I went in and made it so it stays in outside position. Wow now air is blowing out of vents atleast. For some reason the ac is not cold yet but heat works good? SO did dealership just lie or is something else maybe wrong with ac. I put on ac machine at work and it reads it has the right amount of ac crap in system. im stumped.
Now i have new issue. Driving down the road at night with lights on sometimes my headlights flash on and off. dash light are staying on so not thinking dash switch, It does with and without brights the only thing it doesn't affect are the fog lights. and it doesnt matter smooth road or bumpy. For an 06 i love the moter but hating the darn truck.
Haus720 is offline
post #2 of 3 (permalink) Old 10-13-2009, 11:47 AM
PhilipR's Avatar
Your A/C issue is the blend door....do a search for blend door. There are some cheap fixes out there and you can do it yourself. It's common issue. As for the lights....pull the switch and look at the wires. All the power for th elights run through the switch and they are know to burn out. If that's all good then move out under the hood looking for a loose ground.
-Phil-
PhilipR is offline
post #3 of 3 (permalink) Old 10-13-2009, 07:58 PM
4play's Avatar
what he said, I had the headlamp problem too, I replaced the switch and problem fixed. Before buying parts you might want to look at the wiring connector at the switch to see if its melted too. I remember reading somewhere I think Napa sells a kit ( switch & wiring ) if you need both.
4play is offline
coolent probs. big peter 6.5L Diesel Engine 15 02-12-2009 01:41 AM
Window probs. Diesel Dog General Ford Truck and Excursion 4 04-02-2007 12:57 PM
Funny probs with my new 6.5 vtveggiburb 6.5L Diesel Engine 10 03-31-2007 09:53 PM
Edge Probs! imported_BigPSD 2003-2007 6.0 Tuner Forum 1 03-13-2007 02:02 PM
91 F-250 303 5spd probs StrokerAce General Gas Vehicle 3 10-20-2006 03:44 AM
