building a trac bar - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 8 replies and been viewed 1080 times.
post #1 of 9 (permalink) Old 10-16-2009, 10:54 PM Thread Starter
SSpeeDEMONSS's Avatar
building a trac bar
ive been thinking about it lately and there are some nice bars/kits out there but i think i can make a good one. i was thinking of using a Johnny joint on both ends with a decent sized tube. id also make a new bracket for the frame and redo the axle one. im sure i could do this for $200. $250 max. what are your thoughts on this?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 9 (permalink) Old 10-17-2009, 12:11 AM
gone fishin!
i think the bend would be the hardest part, other than that i think it would be easy
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 9 (permalink) Old 10-17-2009, 08:45 PM Thread Starter
what if i could make a straight one?
post #4 of 9 (permalink) Old 10-17-2009, 09:48 PM
gone fishin!
not sure if you could unless you where lifting the truck a bunch and didnt have to worry about clearing the diff, if you tried to put it out in front of the diff i think the geometry would be off.
post #5 of 9 (permalink) Old 10-17-2009, 11:13 PM Thread Starter
why would the geometry be off?
either way, i know i can make a better one. ill see if i get under there and check it out. though i already thought about the bend too.
post #6 of 9 (permalink) Old 10-18-2009, 01:58 AM
TURBOLVR's Avatar
Just remember the bar has to be as close to level as possible @ normal ride height. Youll also want to take out the springs and cycle the suspension all the way each wheel and both to be sure nothing hits/binds.
98.5 CSTD QCSB 4x4
Whipple/Turbonetics chargers,
7x12 stix, .093 lines & tubes
built P-pump,
TUNNELRAM 24-P intake plate,
HBX IC,
PDI T4 3-pc.
O-rings w/mild port&polish
ARP studs
H2 cam
HD pushrods/springs
NE Performance Billet auto,
custom intake horn, grid delete,
electric fans,
leveled by HELL BENT STEEL,
Thuren trac bar,
DSS braced,
RUK control arms,
custom traction bars,
5" duals.
TURBOLVR is offline
post #7 of 9 (permalink) Old 10-18-2009, 05:33 PM Thread Starter
yeah, thats why i was going to make to brackets. we'll see what i come up with then i get in and look.
post #8 of 9 (permalink) Old 10-18-2009, 05:43 PM
TURBOLVR's Avatar
If the truck is lifted its a LOT easier. Just be sure the welds are solid. nothing scarier than losing steering control of an 8000 lb truck after hitting a pothole on the highway!
But really not rocket science and should do just fine.
How do the jonny joints hold up to road grime, grease and oil?
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
post #9 of 9 (permalink) Old 10-18-2009, 07:10 PM Thread Starter
johnny joints get used a lot in links. i dont think they would have any problem standing up to the abuse.
Trac-Lok Rebuild kruser02 General Ford Truck and Excursion 3 03-06-2009 10:40 PM
True Trac MikeRJ13 General Ford Truck and Excursion 4 06-26-2007 09:03 PM
05 trac bar bushing EPDP99 General Ford Truck and Excursion 51 03-29-2007 03:46 AM
lg-agri trac ron256 Utility & Farm Tractors 1 04-25-2006 12:05 PM
07 sport trac 03fatness The Parking Lot 7 04-21-2006 03:29 PM
