BHT3B and BHT3E turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bigfury, this thread has received 4 replies and been viewed 1958 times.
post #1 of 5 (permalink) Old 10-18-2009, 05:10 PM Thread Starter
Can someone tell me the difference in these turbos?Reason for asking is there is one on e-pay cheap.Would like to know if it be of good use in a set of twins? Install on a 6BT,VE pump,mildly tweaked working along with a S300G.Thank you in advance.
Bigfury is offline
post #2 of 5 (permalink) Old 10-18-2009, 05:31 PM
SSpeeDEMONSS's Avatar
i know the 3B is a good bottom charger but i dont know about the 3E.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 5 (permalink) Old 10-18-2009, 05:50 PM
TURBOLVR's Avatar
Twins on a VE truck are often over-kill as the pumps dont fuel real hard but if the turbo is more than $400 used or $600 new dont bother as they can be had new and in YOUR choice of housing/wheel for under $700 new. Chances are you would want a 74 comp with a 22cm housing for a good fast towing twin set, no? Is the truck intercooled?
98.5 CSTD QCSB 4x4
Whipple/Turbonetics chargers,
7x12 stix, .093 lines & tubes
built P-pump,
TUNNELRAM 24-P intake plate,
HBX IC,
PDI T4 3-pc.
O-rings w/mild port&polish
ARP studs
H2 cam
HD pushrods/springs
NE Performance Billet auto,
custom intake horn, grid delete,
electric fans,
leveled by HELL BENT STEEL,
Thuren trac bar,
DSS braced,
RUK control arms,
custom traction bars,
5" duals.
TURBOLVR is offline
post #4 of 5 (permalink) Old 10-18-2009, 07:10 PM Thread Starter
BHT3B or BHT3E
In the process of installing a powerstroke I/C.With any luck I may be able to get the turbo for less than $200,a remanifactored unit.Thank you for your input.
Bigfury is offline
post #5 of 5 (permalink) Old 10-18-2009, 07:19 PM
TURBOLVR's Avatar
try to be sure the ex. housing is a 27cm or smaller or it wont spool without a lot of RPMs and/or fuel. Also try to be sure it has no "weird" flanges, as these can add expense and frustration to the project.
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
bht3b smokeisfun 5.9L Cummins 12 Valve (1994-1998.5) 0 10-14-2007 03:32 AM
Borg Warner BHT3E Turbocharger Brand New Strokerin Whats Been Sold 4 09-10-2007 02:38 AM
Borg Warner BHT3E Turbocharger Brand New Strokerin Whats Been Sold 2 09-03-2007 06:06 AM
Bht3b IGotIt 5.9L Cummins 12 Valve (1994-1998.5) 5 04-25-2007 03:12 AM
New HTT BHT3B Jonathan Trantham Whats Been Sold 0 01-10-2006 01:16 AM
