Need help with a 5.9 Gasser! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WantACummins?, this thread has received 1 replies and been viewed 542 times.
post #1 of 2 (permalink) Old 11-03-2009, 05:04 AM Thread Starter
Ok well it's the girls truck (2002 Ram Automatic 70,xxx) and I can't seem to figure out whats going on with it. It started about a month ago, when you start the truck when it's cold it has a really rough idle and if you try and drive it cold, it will studder really bad as if it's "loading up" and almost stall out. However when it gets warm it will run ok. With the exception of it drinking gas. Which most gas 5.9's do anyway. About 2 months ago I changed the cap, rotor and wires, I also replaced the air filter. There isn't a OBD 2 code that comes up or anything. What could this be? Plugs, maybe the EGR valve? I'm lost. Thanks for any help fella's
WantACummins? is offline
post #2 of 2 (permalink) Old 11-03-2009, 12:50 PM
PhilipR's Avatar
IAC motor gummed up on the TB?
-Phil-
PhilipR is offline
Need help with a 5.9 gasser WantACummins? General Gas Vehicle 14 12-01-2009 05:45 AM
6.5L TD to 454 gasser.... besanders 6.5L Diesel Engine 4 09-09-2007 12:07 AM
Gasser Advice imported_Tommeyboy General Gas Vehicle 4 10-03-2006 09:39 PM
Got me a gasser. Got Diesel Road Kill, Bench Racing 2 09-20-2006 09:02 PM
Got a ricer with the gasser cummins_cowboy Road Kill, Bench Racing 1 08-16-2006 05:40 PM
