front wheel hub removale - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 375.0ford, this thread has received 4 replies and been viewed 882 times.
post #1 of 5 (permalink) Old 11-10-2009, 11:04 PM Thread Starter
I own a auto repair shop and would like to know if anyone has knowledge of a tool or methed for removing the front wheel hub so as to replace the axle u joint, I live in new england and salt air and salt from winter make these hubs almost imposible to get off, I tried getting one off a 06 2500 4x4 no way would it come out, any help or idea's would be greatly appreciated.
03 F250 CC FX4 5.4 Now a Cummins 5.9 CR
1937 Ford 2dr sedan slantback 5.0 HO
375.0ford is offline
post #2 of 5 (permalink) Old 11-11-2009, 04:30 AM
4play's Avatar
Its hard to explain but you can use like a 3/8" extension between the hub or against a slightly loose hub bolt and then the frame ( extension wedged from axle bracket or frame and to the hub or loose hub bolt ) then use the power steering to turn the wheel and hub will pop loose. There is a really good write up on this somewhere with good pics and explanation.
oh here it is...https://www.thedieselgarage.com/forum...ht=hub+bearing
4play is offline
post #3 of 5 (permalink) Old 11-13-2009, 02:26 AM
Lots of PR blaster, lots of heat, a small sledgehammer, and beat the heck out of it. It took me 5 hours of consistent effort to work mine out, but they will come out. I also used a wedge to get between the bearing and the knuckle and pryed it apart that way.
Haggs2002 is offline
post #4 of 5 (permalink) Old 11-21-2009, 08:36 PM
2005/2500, AFE stage II.
I used a large gear puller and with a little bit of effort they came off. JP
socofn is offline
post #5 of 5 (permalink) Old 11-29-2009, 11:29 PM
My friend with a 04.50 dodge 4x4 just has his hubs removed for front end work and the dodge tech used a sledge hammer. Salt from the alaska's roads was the story. $2400.00 of work on his warranty.
chevman
chevman is offline
Front Wheel Bearings rsjohnsn General Ford Truck and Excursion 14 03-14-2008 12:08 AM
front wheel bearing 98 4x4 cookiemonsterblue 5.9L Cummins 12 Valve (1994-1998.5) 1 04-18-2007 02:53 AM
How To Stop Front Wheel Hop skter97 2003-2007 6.0L Power Stroke 10 11-16-2006 10:52 PM
dash removale ???? WTB gauges aldo_45030 General Ford Truck and Excursion 1 07-19-2006 11:54 AM
Front Wheel Bearing ????'s Billysgoat General Dodge Discussion 8 09-13-2005 12:48 AM
