Driveline Angles and Lifts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 4 replies and been viewed 934 times.
post #1 of 5 (permalink) Old 01-09-2010, 07:54 AM Thread Starter
BlowinSmoke's Avatar
I put this in general discussion because its a general inquiry.
I was wondering if anyone on here was good with figuring whats need to angle the driveshaft correctly.
I dont believe the transmission mounting was dropped. Small possibility it may have been.
The rear axle sits with no angle of degree to it.
With a 6" Lift how much would you have to angle the rear axle up so the angles work well together since the transfercase isnt angled down.
Thanks for the help
BlowinSmoke is offline
post #2 of 5 (permalink) Old 01-11-2010, 12:52 PM
What are sparkplugs
ICEMAN3005's Avatar
2-4 degrees upward no more than 3 on front will mess up steering caster can go alot farther on rear, with a 6 inch lift 2 degrees should be fine. if its a skyjacker lift should already have 2 or 3 degree angle blocks installed on bottom of springs to correct drive line angle. front will have to go aftermarket arms that you can adjust.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #3 of 5 (permalink) Old 01-11-2010, 09:58 PM Thread Starter
Cool. Well thats the tricky part because whatever lift was on it before there was absolutely no taper to the lift blocks at all just a solid 3" block.
post #4 of 5 (permalink) Old 01-11-2010, 10:31 PM
Eaton and Alison both have programs, that you put in all the angles and it will tell you if they are OK. You may have to phone around to find someone that has the program without it you can destroy your gear train in a big hurry.If they tell you, it is not needed and they know how to without the program ask for a power-train guarantee. Do it right or leave it alone, is a good way to do things. Just a thought!
Johnp3 is offline
post #5 of 5 (permalink) Old 01-12-2010, 04:28 AM Thread Starter
What about using a driveline with 3 u joints instead of 2 ? Could that work?
lifts blueking General Ford Truck and Excursion 13 08-04-2009 03:47 PM
lifts for a 91 yj pacbrake 4X4 Offroad Forum 7 01-07-2009 11:29 PM
lifts hooked again 5.9L Cummins 12 Valve (1994-1998.5) 1 03-19-2008 04:21 AM
Lifts pedro_8149 7.3L and 6.9 IDI (Pre 1994) 3 10-23-2007 05:38 PM
Lifts strokerut99 1994-2003 7.3L Power Stroke 9 04-20-2006 12:53 AM
