Fan blower motor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 3 replies and been viewed 978 times.
post #1 of 4 (permalink) Old 02-17-2010, 06:35 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Fan blower motor
i noticed that our fans dont blow out enough such as AC or heat. But i was just wondering if you could get like a bigger fan blower to produce more heat or AC. Thanks guys
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 4 (permalink) Old 02-19-2010, 04:03 AM
ADMIN/MAFIA
neeltburn's Avatar
Check to see if your fan works in all the positions of the switch. I lost the HVAC controls on my Dakota, I replaced the controls and it all worked right again. I slowly lost the controls so this may be your issue.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 4 (permalink) Old 02-19-2010, 04:17 AM Thread Starter
It does! Just dont put out enough to actually feel it. Ill get in my grannies truck and turn on the fan, and your feeling it. I guess what im trien to say is there a way to increase the fan speed?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 4 (permalink) Old 02-19-2010, 05:29 AM
4play's Avatar
I would start by guessing leaves/debris are trapped in the HVAC case. The debris will get trapped by the the A/C Evaporator and restrict airflow
4play is offline
Blower motor resistor replacement Zaairman Ford - Modification instructions, Product installs and Tech Articles 4 12-28-2009 06:31 AM
Blower motor resistor replacement Zaairman General Ford Truck and Excursion 7 11-13-2009 10:00 PM
Blower Motor Resistor?? a26rock 2003-2007 6.0L Power Stroke 5 06-16-2009 03:13 AM
my blower motor doesnt work jakebrakeIH General GM Truck Forum 3 01-23-2008 04:41 PM
Blower motor POWER STROKE 99 General Ford Truck and Excursion 1 01-02-2008 11:12 PM
