Tires, Tires, Tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hammer Down, this thread has received 6 replies and been viewed 946 times.
post #1 of 7 (permalink) Old 03-02-2010, 11:57 AM Thread Starter
Tires, Tires, Tires
I have a set of 315/65/18 on my 2500 with a slight lift. I would like to keep the tire height the same, but I want a narrower tire. They are so wide they really suck in the the snow. Any ideas?
Hammer Down is offline
post #2 of 7 (permalink) Old 03-04-2010, 02:07 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
If a 70 wide tire wont fit on the 65 wide rim, your gonna have to get new tires and rims like a 315/70/18 or maybe a 315/75/18 but i dout it if they have a 75wide tire in a 18rim but i could be wrong.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 7 (permalink) Old 03-06-2010, 01:58 PM Thread Starter
Sorry, they are 325/70/18 and what u just posted went way over my head. The tread pattern measuers 11in wide and i would like something about the same height but narrower. Any ideas?
post #4 of 7 (permalink) Old 03-06-2010, 02:15 PM
2nd Gen Guru
Mopar1973Man's Avatar
The best thing I can say is hit a tire shop and talk to the manager or shop professionals. Find out what hes got for sizes...
Up here in Idaho I found that 235/85 R16 is a excellent size for snow. Bit this is way too small for your truck setup... My orignal size was 265/75 R16 just horrid for snow traction.
Mopar1973Man is offline
post #5 of 7 (permalink) Old 03-06-2010, 06:25 PM
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #6 of 7 (permalink) Old 03-07-2010, 12:21 AM
2nd Gen Guru
Another way to look at it...
Measure out the contact patch of your tire. Say your 315's and you'll see that its very wide. But now weight just a single axle.
Now take a narrow tire and do the same thing you find the pound per area is MUCH greater giving you better traction in the snow and allowing you to push down through it.
Like my truck... My tires are 6.5 inches wide and has a contact patch of 7 inches roughly. My combined front axle weight is 4,400 pounds. So a single axle is 2,200 pounds with a total contact patch of 45.5 Sq Inches. Now for my rear tires are the same size of patch but there 2,860 pound combined so 1,430 per axle...
Now compare to your contact patch...
I got to admit when wood hauling season comes I switch back to my Cooper STT 265/75 R16 because the wider face allows a better bite for offroad traction and allows me to skid trees much farther...
post #7 of 7 (permalink) Old 03-08-2010, 12:40 PM
There are tire size charts that show tread width and loaded radius, several of the tire dealers go to the Rubber Manufacturs Association that lists target dimentions and rim sizes.
IIRC 8R19.5 has the dia, weight capacity and is skinnier.
Sipeing with a 3/8 repeating pattern is good on snowpack, self cleaning blocks on fresh snow and for Ice the retreads with inclusions in the tread work well. This combination is not on the market, the closest is HiTek retreads ( I think they moved from Denver to South Dakota)
Tire sizes are currently mostly sectional width ( sidewall to sidewall ) times aspect ratio ( the second number with a decimal point ) plus 1/2 the rim diameter for rolling radius. Tires are metric and rims usually inch measurement.
81 Isuzu /C223na, 5spd
keydl is offline
What tires do you run Superstroker General Ford Truck and Excursion 24 09-01-2009 09:56 PM
Tires??? tahoedmax General GM Truck Forum 10 09-26-2007 02:51 AM
Tires???????? imported_coalfed 5.9L Cummins (2003-2007.5) 11 03-20-2007 04:00 PM
Tires! Tires! Tires! Opinions! Suggestions! Pegsmi98 General Ford Truck and Excursion 4 03-13-2007 07:16 PM
Tires???????? imported_coalfed 5.9L Cummins (2003-2007.5) 11 02-23-2007 11:40 PM
