Preferrence of filters. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 6 replies and been viewed 803 times.
post #1 of 7 (permalink) Old 03-31-2010, 01:58 PM Thread Starter
BlowinSmoke's Avatar
Tried to find something first before posting out of curiosity.
Are there any preferrences or reccomends for oil and fuel filters for the 1st gen 12v's ?
BlowinSmoke is offline
post #2 of 7 (permalink) Old 03-31-2010, 03:43 PM
PhilipR's Avatar
I prefer the Amsoil Ea oil filters but if you are looking for something you can get locally then Fleetguard is gonna be your best bet. Cummins aproved and made by them as well. Other than Fleetguard I would run a Wix or Baldwin. Napa Gold is Wix, Carquest as well is made by Wix. AC-Delco has a good filter as well as Motorcraft....just stay away from Fram and the other cheap brands.
-Phil-
PhilipR is offline
post #3 of 7 (permalink) Old 04-01-2010, 01:15 PM Thread Starter
Sounds good. I dont like cheap to much on my truck anyways haha unless its a floor mat
post #4 of 7 (permalink) Old 04-01-2010, 03:38 PM
Cheap floor mats may cause Toyota problems
Cut a sample open to see what is inside, Fram has less filter, Perolator has more and Wix has more yet. Fleetguard is at the heavy truck shops, NAPA is everywhere.
Several years back I saw pictures from a Mustang site that tried to find, measure and take pictures of all the brands. Lots of brands but not a lot of manufactures, many were identical under the paint.
A bypass filter will make the full flow filter much less important.
81 Isuzu /C223na, 5spd
keydl is offline
post #5 of 7 (permalink) Old 04-01-2010, 07:13 PM
PhilipR's Avatar
Here is some filter info:
http://minimopar.knizefamily.net/oilfilters/index.html
-Phil-
PhilipR is offline
post #6 of 7 (permalink) Old 04-03-2010, 02:51 PM Thread Starter
Definitely dont need Toyota problems
Interesting. Well less wouldnt be good. More is better, but could better not be as good? Maybe I'll do some diggin once I get some change
post #7 of 7 (permalink) Old 04-03-2010, 04:38 PM
I have generally managed to put a bypass filter on most, usually second hand from a junk.
Luberfiner, Baldwin, Fleetguard, Wix, NAPA, Perolator - tearing down junk motors I never found a filter problem, even with major sludge inside.
Store brands and Fram showed signs of plugging and bypass on some.
keydl is offline
Oil filters, fuels filters deltadude 2003-2007 6.0L Power Stroke 44 09-15-2009 12:57 AM
Filters 04.5cumminsman Common Rail 2 06-03-2009 02:40 PM
Oil Filters gm1236 5.9L Cummins (2003-2007.5) 10 05-13-2009 10:51 AM
oil filters 700rmk Supporting Vendors Forum 2 05-02-2009 12:00 AM
How much for filters? 444turbodiesel 2003-2007 6.0L Power Stroke 7 12-11-2006 09:37 PM
