Gooseneck Hitch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 14 replies and been viewed 1922 times.
post #1 of 15 (permalink) Old 04-03-2010, 09:46 AM Thread Starter
BlowinSmoke's Avatar
Gooseneck Hitch
Gooseneck hitch on a lifted truck, could it work or not?
BlowinSmoke is offline
post #2 of 15 (permalink) Old 04-03-2010, 01:25 PM
Administrator
fordt's Avatar
Images: 5
What are your concerns? It can work, just depends on the height of the truck and the height of the trailer neck.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #3 of 15 (permalink) Old 04-03-2010, 01:50 PM Thread Starter
Pretty much that the truck is too high really, I've got a 6inch lift and 35inch tires. Thought that it would be pretty hard to find a trailer that would work and not jack the end of it into the ground.
post #4 of 15 (permalink) Old 04-03-2010, 01:57 PM
Administrator
fordt's Avatar
Images: 5
I hada Chevy with 6" lift and 33's and my GN was fine. Your truck I am sure is higher even more than the tire difference, since they are higher in stock form. Take it to the trailer and test it. Even if you don't have a ball, you can back under it and see.
-Wayne
fordt is offline
post #5 of 15 (permalink) Old 04-03-2010, 02:13 PM Thread Starter
Sounds good, thanks. Good enough info for a start.
post #6 of 15 (permalink) Old 04-03-2010, 04:24 PM
Trailer can be lifted to fit truck.
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 15 (permalink) Old 04-03-2010, 10:21 PM
Administrator
fordt's Avatar
Images: 5
It can, but depending on what you are going to haul with that trailer it may not be a good idea. You can buy goosenecks with extra high necks. I have a friend with one that he pulls with a truck that has a taller utility bed on it.
-Wayne
fordt is offline
post #8 of 15 (permalink) Old 04-03-2010, 11:24 PM Thread Starter
The possiblities are going to probably turn out to be hay and/or horses. Spouse wants a dually, 2nd gen. As another possibility for tow rig.
post #9 of 15 (permalink) Old 04-06-2010, 01:05 AM
Having a jacked up truck and big tires, then put a heavy trailer on it. It is all good going straight, any problem you have can get real serious quickly, any heavy braking in a corner, you could be i trouble. Just a thought!
Johnp3 is offline
post #10 of 15 (permalink) Old 04-06-2010, 11:53 AM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
I doubt it will work well, I know on stock 3500 a lot of trailers sit at a angle and with some flat beds too.Besides looks it is not safe or good for the truck or trailer. It places at least 75% of the weight on the rear axial of the trailer and tires and I have seen them fail real quick even if it looks not so bad. It makes the trailer tow and handle bad. The animals standing at a angle is not good ether for them or there ability to ride and compensate in the trailer. Also I would venture to say your 35's are not rated heavy enough to carry the weight of most goose necks, unless you have a real light 2 horse or similar. With livestock especially I would be concerned with its overall safety. If you were just going to haul some quads or sleds where weight was not such a factor or animals lives it would be one thing. A dually would be a much better option in my opinion.
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
The Following User Says Thank You to MILKINGCOWBOY For this addition to TDG:
BlowinSmoke (04-06-2010)
Husky 5th wheel hitch and Gooseneck hitch for sale maxxis_mudder Whats Been Sold 1 09-02-2009 09:00 PM
Husky UBS 25k gooseneck hitch and 16k 5th wheel hitch for sale maxxis_mudder Whats Been Sold 1 06-10-2009 10:23 PM
Gooseneck hitch Hardrock_F350 Towing and Hauling 20 03-02-2009 11:21 PM
B @ W gooseneck hitch bigbucks8 Whats Been Sold 1 01-16-2009 05:42 PM
Gooseneck hitch??? Motown Fire Towing and Hauling 2 08-24-2006 10:25 PM
