Front bearing lock nuts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 8 replies and been viewed 828 times.
post #1 of 9 (permalink) Old 04-03-2010, 01:52 PM Thread Starter
BlowinSmoke's Avatar
Is it necessary to reopen your hubs break the torqued lock nuts and re set them again. Just curious here.
BlowinSmoke is offline
post #2 of 9 (permalink) Old 04-03-2010, 07:58 PM
PhilipR's Avatar
Why? The front is a unitized hub bearing that is sealed...no need to retorque IMO.
-Phil-
PhilipR is offline
post #3 of 9 (permalink) Old 04-03-2010, 11:28 PM Thread Starter
Unsure. Told that you should after the bearings have been driven on and the grease is dispersed.
post #4 of 9 (permalink) Old 04-04-2010, 12:23 PM
PhilipR's Avatar
My first set went 250K and then I replaced them only cause I changed the rotors. The set now has 30K+ and were just pulled cause I did the ball joints (which were stock) and the front u-joints. They are in great shape as well. I hope there are some other replies after Easter from some other guys so we can get some thoughts.
-Phil-
PhilipR is offline
post #5 of 9 (permalink) Old 04-04-2010, 11:46 PM Thread Starter
That would be great, unfortunately mines spent at work so I get to post before I head out. Yeah I've never seen anything that says to do so after any sort of mileage. A family member suggested that after doing bearings alot on their own rigs before.
My nuts are torqued, 35ft-lbs for the inner locking nut with a cotter pin for the lock washer, and the outer nut is torqued to 185ft-lbs. I just went in between the values of the posted threads. It seems to be working fine, I went in between the 31-39 and 160-205 values since thats what we usually do at work with a torque range.
On another note Happy easter to all
post #6 of 9 (permalink) Old 04-05-2010, 01:17 PM
PhilipR's Avatar
Is this on lock-outs or something? I was thinking it was like my 2nd Gen's unitized hubs?
-Phil-
PhilipR is offline
post #7 of 9 (permalink) Old 04-05-2010, 07:08 PM Thread Starter
Not sure what you mean. The truck is a 4x4 truck with manual locking hubs.
post #8 of 9 (permalink) Old 04-05-2010, 07:15 PM
PhilipR's Avatar
That's what I thought. I was thinking it was like my second Gen and there are no manual locking hubs. They have sealed unit hub bearings.
-Phil-
PhilipR is offline
post #9 of 9 (permalink) Old 04-05-2010, 07:33 PM Thread Starter
Ah, yeah i just rebuilt them like 60 miles back
front drive lineline will spin but wont lock into front axle Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 3 12-13-2009 07:33 PM
Front end/hub bearing help... 99fordtruckguy 1994-2003 7.3L Power Stroke 9 02-02-2008 11:43 PM
front wheel bearing 98 4x4 cookiemonsterblue 5.9L Cummins 12 Valve (1994-1998.5) 1 04-18-2007 02:53 AM
Front Wheel Bearing ????'s Billysgoat General Dodge Discussion 8 09-13-2005 12:48 AM
