Auto to 6 speed swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dave7060, this thread has received 1 replies and been viewed 5275 times.
post #1 of 2 (permalink) Old 04-25-2010, 03:37 AM Thread Starter
So I have a Ford Ranger I am sick to death of with it's four wheel drive problems and being too small. I know of a late 90's Cummins powerd Dodge 4x4 but it's an automatic and I hate auto's. How hard would it be to swap a 6 speed manual into it. Will I have to change transfercase's and driveshafts? Would a 6 speed out of a 1 ton fit or will it have to be out of a 3/4 ton. I just want to know what I'm looking at before I consider buying it. Thanks
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
Pround member #7 of the Canadian club and #4 of the farm club
Dave7060 is offline
post #2 of 2 (permalink) Old 04-26-2010, 05:32 PM
Singles Club #2
smokndiesel7588's Avatar
I just had mine swapped. Its a lot of work, but i think worth it in the end. The input shaft spline for the transfer case is different. (I forget which way it is...but one has a 29 spline shaft and the other has a 23 spline shaft.) If the engine is a 24v, you'd either need to get it reflashed with the manual program (can get software and do it with a Smarty). If the engine is a 12 valve, it's easy since there wont be so many codes thrown. The rear driveshaft has to be shortened, and the front lenghtened. You'd also need the different clutch and brake pedals. And the 6spd can come out of any truck you want it out of..as long as its an NV5600.
Greg
smokndiesel7588 is offline
Replace 4 auto with 6 speed auto? papa skwirl Medium and Heavy Duty 15 10-23-2009 03:15 AM
5 or 6 speed swap? mock12v 5.9L Cummins 12 Valve (1994-1998.5) 4 09-26-2009 12:05 AM
6 speed swap from auto Wy Roadblock 5.9L Cummins (2003-2007.5) 2 05-07-2009 06:08 PM
5-speed swap CGCUMMINS 5.9L Cummins 12 Valve (1994-1998.5) 14 01-24-2008 01:48 AM
auto to 6 speed swap? spooled05 5.9L Cummins (2003-2007.5) 3 05-06-2007 08:29 PM
