cheap but good cold air intake? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ehopp88ss, this thread has received 10 replies and been viewed 13657 times.
post #1 of 11 (permalink) Old 04-25-2010, 03:40 AM Thread Starter
2004.5 Dodge Ram 2500
ehopp88ss's Avatar
i want a cheap but good intake and i cant really find anything good
thanks
erik
Erik
My Vehicles
2004.5 Dodge Ram 2500 4X4 QCLB, NV5600, 177K miles, 10000k HIDS, FASS 150, EDGE juice w/ attitude "HOT UNLOCK", VALAIR 650HP DD thanks to DAN'S DIESEL PERFORMANCE!
1988 Monte Carlo SS, 305 SBC, true dual 2.25" t-304 Stainless exhaust, T-Tops, custom red pryzmatique paint, 2 12" Alpine Type-R Subwoofers, 500 Watt Alpine amp, Alpine speakers inside, complete 2 year ground up restoration, 22K miles on rebuild
ehopp88ss is offline
post #2 of 11 (permalink) Old 04-25-2010, 12:08 PM
gone fishin!
do the intake muffler delete and swiss cheese the botom of the airbox, did that to my dads 04 and dropped 80-100 degrees off egt's and cost nuthing.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 11 (permalink) Old 04-25-2010, 03:41 PM Thread Starter
ehopp88ss's Avatar
wait... what now?? haha. whats an intake muffler?
Erik
My Vehicles
post #4 of 11 (permalink) Old 04-25-2010, 04:50 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
It is like baffling in the air intake tube from filter to turbo all it does is restricts the flow of air like mike said take it out and cut the bottom of your stock box and your golden. I have heard and believe the stock box is good for up to 500hp
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 11 (permalink) Old 04-25-2010, 05:13 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
agreed, all you have to do Erik it take the intake tubing off, and there is a plastic section in the middle about 10-12" long and about 5" in diameter, inside that section there are a set of large perforated fins or X looking pieces, as well as ring like baffles on the outside part of the tube, they just slow down the airflow and muffle the turbo whistle
to remove just undo the clamps on either end and pull it out, once you have that done you have to break apart the "muffler" device, on of the ends(cant remember which) will come out, you have to break it a little, i think if you use a flatblade screw driver and pry it apart it will come out, once its out you can slide the guts of it out and replace the endcap(make sure you use jb-weld or some kind of strong glue to keep it together and make it seal against dust), let the glue dry and replace it in your truck, it will increase flow, whistle and cost you $0, you can also take a 2-3" hole saw and punch a couple holes in the bottom of your filter box to allow more cold air through to the filter
hopefully that works for you Erik
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
ehopp88ss (04-25-2010)
post #6 of 11 (permalink) Old 04-25-2010, 06:48 PM Thread Starter
ehopp88ss's Avatar
is it that HUGE tube looking thing that goes down towards the inlet?
Erik
My Vehicles
post #7 of 11 (permalink) Old 04-25-2010, 09:04 PM
gone fishin!
yup!!!! or you can get a 12" piece of 5" exhaust pipe and put it in there.....makes the turbo even louder!!! i used a 1" hole saw and punched about 10 holes in the bottom and sides of the airbox and it made a huge difference.
The Following User Says Thank You to floridaboy For this addition to TDG:
post #8 of 11 (permalink) Old 04-26-2010, 12:12 AM Thread Starter
ehopp88ss's Avatar
ok guys. thanks for the info on this subject. i am literally in the process of doing this right now. i got everything apart. took out the baffle/muffler thingy, and have glued that piece back on.
just waiting for it to dry.
i got another quick question here though. should i take the other plastic piece out of the rubber intake elbow?
thanks
erik
Erik
My Vehicles
post #9 of 11 (permalink) Old 04-27-2010, 01:31 PM Thread Starter
ehopp88ss's Avatar
hey guys!!!! so i gotta thank you for this cheap (well free) intake mod. it makes the darn truck sound like a full blown semi!!!!!!
Erik
My Vehicles
post #10 of 11 (permalink) Old 05-10-2010, 01:13 AM
If you havent you could go with a BHAF as well with the gutted intake tube.
2005 Dodge 2500 Cummins Short bed 4x4 automatic, Rollin Smoke Diesel 5" STRAIGHT TBE, BHAF, Edge Juise w/ Attitude, way to many parts that one can wish for but never enough funds to keep up with the wishes
Cummins_1984 is offline
The Following User Says Thank You to Cummins_1984 For this addition to TDG:
ehopp88ss (05-10-2010)
cold air intake crash6882 1994-2003 7.3L Power Stroke 11 04-09-2009 05:19 AM
Cheap good looking, long lasting tires? NoMoore General Ford Truck and Excursion 18 04-23-2007 04:43 PM
MAC intake????? My friend has a chance 2 get one cheap tell me what you guys think? jebsurf 1994-2003 7.3L Power Stroke 10 04-04-2007 07:06 PM
Good Cheap F450 flat bed wftree General Ford Truck and Excursion 4 03-02-2006 11:44 AM
Cheap intake StrokerAce 5.9L Cummins (2003-2007.5) 2 01-03-2006 05:49 PM
