A/C question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 1 replies and been viewed 595 times.
post #1 of 2 (permalink) Old 04-25-2010, 08:06 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
A/C question
Is there a way you can delete the A/C system and still be operationable. The reason i was asking because i never use it and had the idea to put a auxally fan in its place.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 2 (permalink) Old 04-26-2010, 01:30 PM
PhilipR's Avatar
Dorman makes a bypass pulley kit that allows you to delete the compressor and run the same belt. You can then have the system evac'd and then pull the lines and everything off.
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
97CumminsTurboDiesel (04-27-2010)
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
