wheel cylinder question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smokin24valve, this thread has received 2 replies and been viewed 2090 times.
post #1 of 3 (permalink) Old 05-14-2010, 01:56 AM Thread Starter
WHOS NEXT
I have a 1999 2500 with a dana 70 in the rear with drums brakes. I heard of guys using the dana 80 wheel cylinders in a dana 70. They say it has better stopping power. Is this true and does it work. Thanks for the input.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #2 of 3 (permalink) Old 05-14-2010, 06:41 AM
4play's Avatar
What a lot of people do though and with good results are using Chevy 1 ton wheel cylinders ( WAGNER Part # WC79768 1-3/16" bore or NAPA part #37337 ) Some people have stated that they may be too agressive and I am pretty sure the alternative would be the Dodge Dana 80 (dually) cylinders, Im pretty sure the dually cylinders are a size between the chevy's and 2500 dodge's.
With rear brake issues either being not enough or too much, it might be worth looking at the load proportioning valve attached to the rear axle ( if equipped). I have heard of people adjusting this valve to compensate rear brakes too.
4play is offline
smokin24valve (05-14-2010)
post #3 of 3 (permalink) Old 05-16-2010, 05:48 AM
I have read of using the 1 1/8th wheel cylinder with the 3 in wide shoes as being a good combination for those with a load most of the time.
81 Isuzu /C223na, 5spd
keydl is offline
smokin24valve (05-16-2010)
Wheel Question mxyoest29 5.9L Cummins (1998.5-2002) 2 12-05-2007 01:03 PM
wheel question Sawed Off General Ford Truck and Excursion 4 10-20-2007 05:36 PM
wheel question blowing smoke General Ford Truck and Excursion 11 04-04-2007 12:01 PM
06-24-4 6.0l - Service Remanufactured Engine, Cylinder Block, And Cylinder Head Ident Squatch Ford Oasis requests 0 03-22-2007 02:52 AM
Wheel question Badstang 2003-2007 6.0L Power Stroke 3 02-13-2006 09:18 PM
