Light Bar under Rear tailgate? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SuperTaz, this thread has received 6 replies and been viewed 868 times.
post #1 of 7 (permalink) Old 05-18-2010, 06:11 PM Thread Starter
Anyone put an LED light bar under their rear Tailgate? I've seen other Trucks with them and I'd like to add one. My question is this, What do you do about the spare tire hole that you use to lower the tire from under the truck? Does the light bar just cover it up and your screwed if you get a flat? I've seen Fords and Chevy's with the light bar curious what Dodge owners do?
I've got an 08 Diesel Mega Cab, but I'm sure the set up is the same for all Dodge Trucks.
Thanks for anyone who has any idea's!
Brent
SuperTaz is offline
post #2 of 7 (permalink) Old 05-20-2010, 05:17 PM
H.O. Cummins
bechapman1979's Avatar
I put the light bar on my kinda low and it covers most of the hole to lower your spare tire. The light bar itself is pretty flexible and i can still get my tool in to lower the tire no problem. Havent had to yet but that was one of the first things i checked. as you can see in the picture there is some room to raise it up a little bit if you wanted too
Hope this helps
Britt
4 more years ... sigh ...
Texas Club #3
05 dodge, g56 6 speed, PPE excellerator, AFE mega cannon, Banks monster ram intake, redneck exhaust, 5" lift with 37" cooper tires.
bechapman1979 is offline
post #3 of 7 (permalink) Old 05-21-2010, 02:23 PM Thread Starter
Bechapman1979,
Thanks for the pic, I wondered how flexible they would be. I'm not sure if I have a dibit like yours in the molding but I'll be sure to check at lunch today!
Thanks for the response and the extra mile with the pic!! Have a good weekend
Brent
SuperTaz is offline
post #4 of 7 (permalink) Old 05-21-2010, 03:26 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
You have the molding Brent, every truck has it. I have the Recon bar on my truck, looks awesome with the LED taillights and 3rd brakelight.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #5 of 7 (permalink) Old 05-21-2010, 04:18 PM
H.O. Cummins
I forgot why I had it hung low in the first place. If you mount it too high the mounting screw will rub the paint every time you open or close the tailgate and end up with a rub spot. i didn't notice right away and it ate into it pretty good as you can see. so make sure it doesn't rub and hang it as low as you can to make sure you don't end up with a chunk of paint missing from your tailgate like mine. Of course i got many chunks missing and dents from misfires of heavy limestone being hand loaded/tossed in the bed.
Good luck and let us know when it is done
Britt
Texas Club #3
post #6 of 7 (permalink) Old 05-24-2010, 01:58 PM Thread Starter
Yep your right, it is molded. I just didn't remember that. Thanks for the pointer in regards to rubbing. I'll probably use 3m tape so I don't have to drill holes. We'll see....Thanks I'm also looking for the side amber lights that go under the doors on the rocker pannel so when I finally get them ordered and all done up I'll be sure to post...
Thanks again,
SuperTaz is offline
post #7 of 7 (permalink) Old 05-26-2010, 12:19 PM
Singles Club #2
smokndiesel7588's Avatar
I pulled the molding off of mine and put the bar right over the hole. I dont have a spare tire though (since the truck didnt come with one) . The recon lights come with 3M adhesive and screw holes as a secondary means for mounting.
Greg
smokndiesel7588 is offline
60" Recon Line of Fire LED tailgate light TxFireman1972 Whats Been Sold 2 02-17-2009 02:50 PM
Rear bumper light wiring?? Can anyone help? MWhite Medium and Heavy Duty 4 09-11-2007 07:02 AM
Marker light on rear of truck bed bigs rig 1994-2003 7.3L Power Stroke 2 12-13-2006 04:46 PM
LED tailgate light bar on our "Diesels" 2006copperPSD General Parts and Accessories 4 12-08-2006 12:24 AM
96 Dodge Tailgate & Rear Bumper bigdraft Whats Been Sold 0 03-23-2006 07:48 PM
