1st Gen. Door Locks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 2 replies and been viewed 1126 times.
post #1 of 3 (permalink) Old 05-23-2010, 02:52 PM Thread Starter
BlowinSmoke's Avatar
1st Gen. Door Locks
Trucks got power windows and door locks. Key in the door wont turn lock down and the switch doesnt do anything either, no noise is heard when pressing it either. Any suggestions before the door gets torn apart ?
BlowinSmoke is offline
post #2 of 3 (permalink) Old 05-24-2010, 06:02 AM
'93 has a plastic vent on the edge of the door, don't know if yours does. Common cause of failure to change locked to unlocked is a corroded door lock motor, they are usually mounted with a 1/4 in rivet on the edge of the door under the latch. drill the rivet or remove the panel and unclip the lock motor.
Second common is hardened grease in the latch case, take it out and pressure wash or degrease and regrease it with white grease or synthetic.
No sound from either door? Fuse might be out from the stuck motor. The switches also corrode and quit, they can be disassembled and the contacts cleaned.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 3 (permalink) Old 05-24-2010, 01:48 PM Thread Starter
Ok. My first real guess that the motor was no good for the locks. but now I can look for some grease too. Thanks.
door locks axe man 2003-2007 6.0L Power Stroke 7 05-14-2010 05:05 PM
Door Locks patriot2500 5.9L Cummins (2003-2007.5) 31 02-23-2010 02:53 PM
02 Ram door locks? neeltburn The Parking Lot 3 01-01-2010 01:40 AM
door locks tgf 1994-2003 7.3L Power Stroke 4 05-19-2009 11:27 AM
Door Locks won't let me in. Got Diesel General Ford Truck and Excursion 3 01-18-2007 02:29 AM
