NEED some help with my a/c!?!?! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ehopp88ss, this thread has received 26 replies and been viewed 3176 times.
post #1 of 27 (permalink) Old 06-01-2010, 03:01 AM Thread Starter
2004.5 Dodge Ram 2500
ehopp88ss's Avatar
i recently tried to fix my a/c (was ice cold when i got it and now theres nothing. found a leak in the system. fixed it. now it holds freon but doesnt blow cold.
i have 175 on the high side and 5 on the low side. what should be the normal?
i am thinking there is a blockage somewhere. not sure.
ANY input would be greatly apprecaited. im flying blind here.
thanks
erik
Erik
My Vehicles
2004.5 Dodge Ram 2500 4X4 QCLB, NV5600, 177K miles, 10000k HIDS, FASS 150, EDGE juice w/ attitude "HOT UNLOCK", VALAIR 650HP DD thanks to DAN'S DIESEL PERFORMANCE!
1988 Monte Carlo SS, 305 SBC, true dual 2.25" t-304 Stainless exhaust, T-Tops, custom red pryzmatique paint, 2 12" Alpine Type-R Subwoofers, 500 Watt Alpine amp, Alpine speakers inside, complete 2 year ground up restoration, 22K miles on rebuild
ehopp88ss is offline
post #2 of 27 (permalink) Old 06-01-2010, 03:20 AM
ADMIN/MAFIA
neeltburn's Avatar
thanks
erik
do you have access to a set of HVAC gauges?
Knowing what your high and low side pressures are will help!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 27 (permalink) Old 06-01-2010, 04:18 AM Thread Starter
ehopp88ss's Avatar
ya. i think thats what my dad used. not too sure. it was 175 on the high side and 5 on the low side
Erik
My Vehicles
post #4 of 27 (permalink) Old 06-01-2010, 06:26 AM
Actually the question is refrigerant. R12 or R134A?
R134A high side is temperature dependent and 150 to 300 low side is around 30.
If the system was opened to fix the leak, it is normal to replace the drier and then vacuum the air out. If it came with R134A there will be a label for the correct charge weight, if converted start with 70% of the R12 label as a limit.
Get an enthalopy table from the library, temp and humidity - inside and outside make a difference.
81 Isuzu /C223na, 5spd
keydl is offline
ehopp88ss (06-01-2010)
post #5 of 27 (permalink) Old 06-01-2010, 11:34 PM Thread Starter
ehopp88ss's Avatar
would my system have an orifice tube or an expansion valve?
Erik
My Vehicles
post #6 of 27 (permalink) Old 06-02-2010, 08:12 AM
Most were expansion valves on the old stuff that I see, I just drive the later ones. Chevy is mostly orifice tube and Ford changed a lot, Freightliner expansion valve and KW same
keydl is offline
post #7 of 27 (permalink) Old 06-02-2010, 03:19 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
We have orifice tubes, I just had mine replaced because it wasn't blowing cold. That was 3 weeks ago and it was ok, but now its blowing hot again. I think my compressor is shot.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #8 of 27 (permalink) Old 06-02-2010, 03:59 PM Thread Starter
ehopp88ss's Avatar
i see. well 4 months ago when i got mine it was blowing ice cold and now its hot. should i worry about the tube or the compressor? or should i replace them both?
also, do you know what the pressure's should be on a set of HVAC gauges?
Erik
My Vehicles
The Following User Says Thank You to ehopp88ss For this addition to TDG:
keydl (06-03-2010)
post #9 of 27 (permalink) Old 06-02-2010, 05:39 PM
PhilipR's Avatar
What about the blend door issues?
-Phil-
PhilipR is offline
post #10 of 27 (permalink) Old 06-02-2010, 06:16 PM Thread Starter
ehopp88ss's Avatar
well thats the thing. i know they are notorious for that but it still moves (slowly) but it moves. you can hear it slam. but i am thinking i may still take a look at that
Erik
My Vehicles
