bolt pattern for rims - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 2 replies and been viewed 801 times.
post #1 of 3 (permalink) Old 06-03-2010, 01:10 PM Thread Starter
cumminsdiesel's Avatar
Would rims off a 97 2500 fit on a 91 250 or are they diffrent?
cumminsdiesel is offline
post #2 of 3 (permalink) Old 06-04-2010, 03:02 AM
H.O. Cummins
bechapman1979's Avatar
Dodge has used the 8 on 6.5 bolt pattern from 1946-current. They haven't changed the bolt pattern in a while only due to recent upgrades in brake hardware the smallest rim you can run on a third gen dodge is a 17 inch rim
hope this helps
Britt
EDIT: this is the bolt pattern for 3/4 and 1 ton applications only
4 more years ... sigh ...
Texas Club #3
05 dodge, g56 6 speed, PPE excellerator, AFE mega cannon, Banks monster ram intake, redneck exhaust, 5" lift with 37" cooper tires.
bechapman1979 is offline
post #3 of 3 (permalink) Old 06-04-2010, 06:51 AM
The offset is different - '91 is centered and '94 & later are offset enough that the bed will bite the side of the tire when loaded on a 2 wd, won't bolt to the front because a ball joint is in the way.
81 Isuzu /C223na, 5spd
keydl is offline
bolt pattern topflight250 General Ford Truck and Excursion 4 12-08-2009 03:16 PM
bolt pattern seandonato73 5.9L Cummins (1998.5-2002) 2 04-15-2009 12:07 AM
OBS Bolt pattern GilroyRacing General Ford Truck and Excursion 3 04-12-2008 09:00 PM
Bolt pattern and lug size catdude 5.9L Cummins (2003-2007.5) 0 02-08-2008 12:36 AM
Bolt pattern doob51 5.9L Cummins 12 Valve (1994-1998.5) 4 03-02-2007 03:35 PM
