Diesel Truck Forum - TheDieselGarage.com - View Single Post - 2013 Ram 3500 Vibration
View Single Post
post #2 of (permalink) Old 02-18-2014, 01:26 AM
Johnp3
A bad shock will do that, after a trip just feel them if they are warm then they are good if cold they are junk.
Jack up the wheels and spin them see if a trie is out of round, I take it you had the wheel hub tightened up? Look at the brake rotors and see if one is cracked or if drums, look for a weight missing. Even with the drive shaft balanced is it Phased corectly?
If everything looks good put it on a set of stands, and run it up gently. or if you can get someone to drive it and you look from the back or at each side.
Just a thought
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
task125 (02-19-2014)
