Lifts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 6 replies and been viewed 2810 times.
post #1 of 7 (permalink) Old 06-16-2010, 03:27 AM Thread Starter
cumminsdiesel's Avatar
Lifts
I have a 91 2500 and want to be able to fit 35's but cant decide on what size lift. Just wondering if some first gen guys can post some pics of there trucks and tell me what size lift there running. Thanks
cumminsdiesel is offline
post #2 of 7 (permalink) Old 06-16-2010, 02:42 PM
BlowinSmoke's Avatar
Got all 4 Leaf springs replaced by custom leafs at 6" by Alcan Spring they are a colorado company and hand bend their springs. I'm satisfed with the work, they take your specifications into consideration and make them to that. I'm not even using blocks.
As far as shocks I just got a set for a 5" lift from my local 4x4 dealer since no one seemed to have 6" shocks for the truck. 5" shocks run in between their minimum and max range so extending them an extra inch doesnt really matter.
For tires I'm running 35" Toyo M/T's, not entirely satisfied but thats easily changeable if you can afford it.
The trucks a '90 350
Hope some of this helps.
BlowinSmoke is offline
post #3 of 7 (permalink) Old 06-17-2010, 08:18 PM
BigRed Cummins's Avatar
Mine fit 36" x 12.50 Hummer bias ply's with only a leveling kit. no rubbing under normal driving.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
The Following User Says Thank You to BigRed Cummins For this addition to TDG:
cumminsdiesel (06-23-2010)
post #4 of 7 (permalink) Old 06-18-2010, 12:41 AM
bmoeller's Avatar
My '92 W250 came with a 4" Superlift Softride. Running Cooper SST 315s. Rides a LOT better than the stock 1st gens I ever test drove. Rancho shocks on this one.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 7 (permalink) Old 06-18-2010, 02:22 AM Thread Starter
I talked to a guy with 2" lift springs up front and he said he could only fit 33s. is this right?
post #6 of 7 (permalink) Old 06-18-2010, 07:08 AM
Got to love options
The Following User Says Thank You to BlowinSmoke For this addition to TDG:
post #7 of 7 (permalink) Old 06-18-2010, 03:13 PM
Like I said, I only leveled the truck out, with a combination of a longer shackle, and a re-arched set of front springs and it clears 36 x 12.50-16.5 Goodyear Wrangler Military tires just fine. Its probably 3-4 inches higher in the front then when I got it. I have 315/75-16 Toyo Open Country MTs on it right now and they have no problem clearing. I also have very near stock backspacing, which helps. If you have a wheel that sticks out real far, then it is more likely that you will rub.
2003 SVT Cobra
1984 Chevy K10
lifts blueking General Ford Truck and Excursion 13 08-04-2009 03:47 PM
lifts for a 91 yj pacbrake 4X4 Offroad Forum 7 01-07-2009 11:29 PM
lifts hooked again 5.9L Cummins 12 Valve (1994-1998.5) 1 03-19-2008 04:21 AM
Lifts pedro_8149 7.3L and 6.9 IDI (Pre 1994) 3 10-23-2007 05:38 PM
Lifts strokerut99 1994-2003 7.3L Power Stroke 9 04-20-2006 12:53 AM
