Glow Shift Gauges - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 1 replies and been viewed 931 times.
post #1 of 2 (permalink) Old 07-02-2010, 01:49 AM Thread Starter
cumminsdiesel's Avatar
Glow Shift Gauges
Any one ever use these? Any good? I can get boost,pyro, fuel press with dual pillar pod and single dash mount for $250.00. Also i know boost is mechanical, what about pyro and fuel.
cumminsdiesel is offline
post #2 of 2 (permalink) Old 07-03-2010, 12:36 AM
bmoeller's Avatar
I have one of their fuel press. gauges on the KW. Seems to work well. Goes up to 145psi.
Gauge is electrical, but pretty easy to hook up. You WILL need to run a ground wire off of one of the terminals. Won't ground through the threads. It is in the instructions.
"Obama = Hoax and Chains"
bmoeller is offline
glow shift oil pressure sending unit balz out 1994-2003 7.3L Power Stroke 0 05-23-2010 11:31 PM
glow shift gauges?????????????/ 08White 6.7L Cummins (2007.5-2011) 11 10-30-2009 01:17 PM
2 gauges, pod, and shift kit for 97 12v SSpeeDEMONSS Supporting Vendors Forum 2 05-16-2009 01:09 PM
SCT User Adjustments (WOT Speed Shift & Shift Pressure) ebusa 2003-2007 6.0 Tuner Forum 1 04-29-2008 03:23 AM
Glow Shift gauges Phoneguy982 General Ford Truck and Excursion 1 07-23-2006 12:02 AM
