Torque Converter Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chiono Diesels, this thread has received 3 replies and been viewed 1022 times.
post #1 of 4 (permalink) Old 07-19-2010, 08:45 PM Thread Starter
Exclamation Torque Converter Question
Im lookin at gettin a 91 2wd Cummins with the auto. I have some questions as this will be my first Cummins maybe . What is the auto tranny in it? It needs a torque converter, how hard is it to replace, and what is a good replacement one? Also how hard is it to replace a torque plate? What is a torque plate? The price is only a cool $1000 for the truck. Thanks
Chiono Diesels is offline
post #2 of 4 (permalink) Old 07-20-2010, 04:07 AM
If the truck is nonintercooled it will have a 727 trans in it. 727 is a nonOD trans.
If the truck is intercooled it will have a 518. The 518 is an OD trans, nonlockup converter.
Torque plate???? Do you mean flex plate????
I never recommend installing a new converter in an old trans. If your going to take the effort to drop the trans to do a converter swap. Rebuild that trans while it is on the ground.
Take my word for it. It would realy make your day to have the trans die a few months later. Then find out that no trany person on this earth would reuse your almost new converter.
Philip is offline
post #3 of 4 (permalink) Old 07-20-2010, 04:18 AM Thread Starter
He said torque plate. But I went and looked at it and decided it would take more money than I really want to put into it. Had a fuel leak, he had to use ether to start it and he couldnt remember the last oil change. Im goin to look at a 93 W250 next
post #4 of 4 (permalink) Old 07-21-2010, 12:29 PM
Where is that truck located????
Philip is offline
Torque Converter Question Texaspsd 1994-2003 7.3L Power Stroke 2 03-30-2009 07:36 PM
Torque converter ? Yellow Yota 5.9L Cummins 12 Valve (1994-1998.5) 4 02-07-2008 03:42 AM
Torque Converter... Cummins_Beast 1994-2003 7.3L Power Stroke 5 11-04-2007 01:11 AM
torque converter question dustin 08 5.9L Cummins (2003-2007.5) 2 08-17-2007 11:23 PM
Torque Converter question norcuron 2003-2007 6.0L Power Stroke 3 04-06-2007 02:09 PM
