OD ISSUE - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 9 replies and been viewed 3075 times.
post #1 of 10 (permalink) Old 07-30-2010, 11:31 AM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
OD ISSUE
Hi,
My GF has a 93 auto and the thing drops out of OD all the time. But it mainly does it when you let OFF the throttle? It will do it at 45 mph or at 70mph and in between,not good. How does the OD sense when it needs to go in or out? Is there adjustments? Linkage problems? Besides this it shifts fine. To me it feels like maybe some kind of vacuum change is doing it,I don't know how they work tho..... Thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 10 (permalink) Old 07-30-2010, 10:34 PM
REDNECK
bigredbrother's Avatar
my 92 had the same problem check the speed sensor on the transfer case and ALL the plugs leading to the transmission if there all good pull your tranny pan and check for metal. also you might want to see if the fluid is burnt maybe flush the transmission
1992 Dodge W250 H1c with 12cm exhaust housing, ground fuel pin, pump turned up, BHAF, Goerend converter, BD valve body, 3in lift springs, bushwacker flares, 36in goodyear II, 16.5in black steel, dipricol boost, pyro, tranny temp gauges, many more to come...
bigredbrother is offline
post #3 of 10 (permalink) Old 07-31-2010, 06:00 AM
The PCM controls the ground on the OD solenoid in the transmission, the inputs are speed control (speedometer), trans temperature (on the front cooling line), crankshaft sensor and the throttle position sensor. Most probable cause TPS, several ways to deal with it for less than $300 for a new one.
81 Isuzu /C223na, 5spd
keydl is offline
post #4 of 10 (permalink) Old 07-31-2010, 01:31 PM Thread Starter
milkin cowboy
Thanks guys.
When you say several ways to deal with it for less than $300 what do you mean? Thanks again
KEEP ON KEEPIN ON
post #5 of 10 (permalink) Old 08-01-2010, 03:59 AM
One is replacing the TPS with a 5k linear potentiometer, another is tapping the governor port on the transmission and adding a pressure switch to ground the lead that goes to the PCM, a switch to ground the lead is another.
keydl is offline
post #6 of 10 (permalink) Old 02-02-2011, 12:43 PM
i would say TPS or transmission fluid temp sensor. My 94 did the same thing, my trans man (along with everyone else) swore up and down it was the TPS, bought it, dropped it in in the parking lot, NO DICE!!! had to sell a used electrical part... complete headache. the temp sensor was bad, along with the sensor to wiring harness connection. i've heard of people hard wiring the trans temp sensor. if that aint it, all you got is to pucker up and get the TPS
Bitin'Binder19 is offline
post #7 of 10 (permalink) Old 02-03-2011, 03:25 PM
Normal failure mode for the temp sensor is 'no OD' but they can go intermittent. Faiure mode for the TPS is electrical 'noise' instead of smooth transition in resistance value.
Poor connections to the sensors are electrical 'noise'.
The 5K linear potentiometer can be plugged in with terminals to the TPS connector and set to a value that lets most PCM modules work normally in using OD, except for the kickdown feature. It also proves the TPS to be either in need of adjustment or defective for less than $10 in parts.
keydl is offline
post #8 of 10 (permalink) Old 02-08-2011, 12:57 AM
Heres one way to check it.
http://www.dieselbombers.com/dodge-d...ensor-tps.html
Doing the potentiometer yourself.
http://www.dieseltruckresource.com/d...ad.php?t=42003
Or installing a dnrcustoms adjustable pot.
http://www.dnrcustoms.com/zen2/index...942637c6851cf8
91 W250, rusty POS, no afc, PODS, AM FP gauge, Isspro boost + pyro, 91.5 W350
921stgen is offline
post #9 of 10 (permalink) Old 02-12-2011, 01:50 AM
Flyingpig's Avatar
Mine did that and I found it was the speedo sensor leaking trans fluid into it.
Who do you call when the lawmakers ignore the law?
Flyingpig is offline
post #10 of 10 (permalink) Old 09-05-2011, 01:30 PM Thread Starter
milkin cowboy
ty guys
KEEP ON KEEPIN ON
Hub Issue powerstrokin8 1994-2003 7.3L Power Stroke 9 01-26-2010 05:13 PM
Issue with my 6.5 jess10 6.5L Diesel Engine 5 09-11-2009 04:17 PM
EGT issue MOPSD250 2003-2007 6.0L Power Stroke 2 08-19-2009 01:06 AM
Anyone Ran Into This Issue OILFIELD TRASH 6.7L Cummins (2007.5-2011) 9 11-14-2007 12:36 AM
tune issue or tranny issue? licketysplit 2003-2007 6.0L Power Stroke 10 02-14-2006 10:58 AM
