weird sound out exhaust - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 5 replies and been viewed 1899 times.
post #1 of 6 (permalink) Old 08-06-2010, 01:09 AM Thread Starter
cumminsdiesel's Avatar
So my 91 almost has like a miss type sound or bogging out the exhaust when you rev it up slowly and I can here it when im driving to. Is this a fuel or timing issue. i turned the pump up, advanced the timing 1/8 inch, turned the stock fuel pin 180 degrees, and put the GSK in it about a week ago. I thought I could here it then but now that I put the 4" exhaust I can really here it now. It feels a bit doggy untill the boost levels really start to build. Any ideas?
cumminsdiesel is offline
post #2 of 6 (permalink) Old 08-06-2010, 04:21 PM
BigRed Cummins's Avatar
that would be the timing. I did the 1/8 bump to mine and it did the exact same thing. I drove it for a year and a half like that with no issues.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
The Following User Says Thank You to BigRed Cummins For this addition to TDG:
cumminsdiesel (08-07-2010)
post #3 of 6 (permalink) Old 08-07-2010, 01:26 AM Thread Starter
other than turning it back down what would fix this?
post #4 of 6 (permalink) Old 08-09-2010, 09:03 PM
I think that more fuel has been said to help. But you will need injectors for that.
2003 SVT Cobra
1984 Chevy K10
post #5 of 6 (permalink) Old 09-19-2010, 04:18 AM
bmoeller's Avatar
Might not be the injectors. Need more fuel pressure/flow from the lift pump.
You can convert the diaphragm pump style over to the piston as is used on the 2nd gen trucks. The pump will look the same, but run at a lower pressure.
http://www.dieseltruckresource.com/d...ll-t93722.html
"Obama = Hoax and Chains"
bmoeller is offline
cumminsdiesel (09-28-2010)
post #6 of 6 (permalink) Old 09-28-2010, 04:05 AM Thread Starter
How much does this cost? If the truck sits for 2-3 weeks without being started it loses its prime and I dont see any leaks. Would the lift pump be to blame more than likely?
Weird sound RHCDIESEL 2003-2007 6.0L Power Stroke 11 06-15-2009 02:06 AM
Weird Sound Under Throttle Notorious6.0 2003-2007 6.0L Power Stroke 4 11-27-2007 08:48 PM
Weird Sound TeamTonkadodge 5.9L Cummins (1998.5-2002) 9 08-07-2007 04:43 AM
weird sound... any ideas kkibbey 2003-2007 6.0L Power Stroke 5 04-03-2006 03:00 AM
Weird Sound?! farmboy 2003-2007 6.0L Power Stroke 5 10-15-2005 12:16 AM
