Wheels and tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RJC, this thread has received 8 replies and been viewed 2184 times.
post #1 of 9 (permalink) Old 10-23-2010, 03:19 AM Thread Starter
RJC
Wheels and tires
I have a 1993 dually W 350 and looking at purchasing stock wheels and tires off a newer Ford dually. They are 17" wheels and wondering if wheels would be the same lug pattern?
Thanks
RJC is offline
post #2 of 9 (permalink) Old 10-23-2010, 08:12 AM
BigRed Cummins's Avatar
They are not. The newer fords with 17's are metric bolt pattern, and will not fit. pre 2002? ish will fit I think.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #3 of 9 (permalink) Old 10-23-2010, 02:17 PM Thread Starter
RJC
I was getting a really good deal on these but not fitting changes things. Did Dodge come out with 17'" that fits our trucks? It may be worth for me to look for wheels to fit tires. They are brand new pull off from the dealer.
Thanks
RJC is offline
post #4 of 9 (permalink) Old 10-24-2010, 03:26 AM
the newer dodges did. don't know what years tho. newer Chevys do too, and they have the same bolt pattern.
2003 SVT Cobra
1984 Chevy K10
post #5 of 9 (permalink) Old 01-25-2011, 05:11 PM
Nadir's Avatar
3rd Gen Dodge wheel have too much backspace. Not sure about the GM wheels but I remember hearing somewhere about the center hub hole being too small on some.
Nadir is offline
post #6 of 9 (permalink) Old 01-29-2011, 04:01 PM
bmoeller's Avatar
True, but a competent machine shop can fix that. Know a guy that did the same with some GM 19.5 rims for his Ram 3500.
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 9 (permalink) Old 02-03-2011, 06:57 PM
The GM wheels are hub piloted and the center hole is about 1/8 th in smaller with the same bolt pattern.
The Ford went to 170 mm bolt pattern around 99.
The backset on later Dodge rims interferes with the front suspension and will mount on the rear but rubs on the box at full load.
81 Isuzu /C223na, 5spd
keydl is offline
post #8 of 9 (permalink) Old 02-07-2011, 10:49 PM
3rd. gen wheels on a 1stgen.
http://www.dieseltruckresource.com/d...w-t255446.html
91 W250, rusty POS, no afc, PODS, AM FP gauge, Isspro boost + pyro, 91.5 W350
921stgen is offline
post #9 of 9 (permalink) Old 02-17-2011, 03:30 PM
Nadir's Avatar
Beware of Spacers/Adapters
Originally Posted by 921stgen View Post
This is how you deal with the backspace issue.
The OP in that DTR thread states "2 inch spacers will work just as well..." That may or may not be true depending on how you like your truck to steer and how long you like your wheel bearings and kingpins to last. Pushing the track width out that much increases tire scrub through the steering plane and adds leverage against the bearings and kingpins.
May or may not be an issue, depending. Personally, I would not go above an inch or 1.25" max to maintain the integrity of the steering and axle design.
Nadir is offline
Tires and Wheels neeltburn Campers 8 11-22-2012 04:50 AM
New wheels and tires! Cummins_Beast 5.9L Cummins (2003-2007.5) 12 05-11-2010 07:10 PM
new (to me) wheels and tires pontiacross General Ford Truck and Excursion 11 03-24-2010 02:11 AM
Used wheels and tires for my 99 250 bigfords Whats Been Sold 8 02-04-2008 06:29 PM
wheels and tires 99stroke Whats Been Sold 0 12-05-2007 02:25 AM
