engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rwells, this thread has received 6 replies and been viewed 1297 times.
post #1 of 7 (permalink) Old 12-10-2010, 07:36 PM Thread Starter
engine light
Hello everyone
I went out to my truck last night its a 93 the engine light was flashing codes. they were 12 and 41. Alt gauge is not moving , and alt is not charging is there an external regulator or is my alt toast. Any help will be much appreciated
thanks.
rwells is offline
post #2 of 7 (permalink) Old 12-11-2010, 05:37 AM
The Alt regulator is built into the PCM.
That code 12 is not listed in the 93 service manual.
code 41 Generator field not switching properly.
Does the CC and A/C and OD (if an auto trans) work????
Philip is offline
post #3 of 7 (permalink) Old 12-11-2010, 04:33 PM Thread Starter
Truck is a 5 speed , cc is working, tach is working,air is working. went for a drive wasn't charging came home, it started charging idling in the drive way and engine light went out.
rwells is offline
post #4 of 7 (permalink) Old 12-15-2010, 05:33 AM
Over on the passenger side wheel well is a harness plug for the alt. Check the terminals in it for corresion or loose.
Also check the main alt charge wire. It has a connection close to that harness plug.
Philip is offline
post #5 of 7 (permalink) Old 12-18-2010, 05:22 PM Thread Starter
Thanks for the tips
Tried the truck this morning not charging cleaned connections nothing .
Smacked the alt bracket with big rubber mallet and it started charging,
Took it for a drive so far so good.
rwells is offline
post #6 of 7 (permalink) Old 12-19-2010, 04:23 AM
Sounds like it is time for new brushes in the alternator.
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 7 (permalink) Old 12-23-2010, 04:13 PM
stillcummin's Avatar
It may be yor crank sensor goin out some how cs and alt are tied together thre is a way to bye pass sensor and use an older external reg for your alt I,ve had the very same problem when I had my 92 with 93 cummins
BLACK 2013 RAM 3500HD BIGHORN EDTION
385hp/850tq AISIN TRANS, ALCOA WHEELS,ROUGH COUNTRY 2.5'' LEVELING KIT, WHEEL TO WHEEL STEPS,B&W TURN OVER BALL,DURAFLAP MUD FLAPS,TINTEDWINDOWS,RIDE RITE AIRBAGS,BIG TEX GRILLEGUARD, I'M SURE THERE WILL ALOT MORE TO COME SOONER OR LATER
stillcummin is offline
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
Help. Engine light came on trkyhunter 2003-2007 6.0L Power Stroke 4 02-20-2008 01:05 PM
Engine light came on...? AMX73 2008-2010 6.4L Power Stroke 3 01-09-2008 07:55 PM
Engine Light??????????? dointime4alivin 1994-2003 7.3L Power Stroke 4 07-21-2007 05:20 PM
