Correct fluid? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bmoeller, this thread has received 23 replies and been viewed 19140 times.
post #1 of 24 (permalink) Old 01-08-2011, 06:05 PM Thread Starter
bmoeller's Avatar
Correct fluid?
Need to change the fluids in my '92 W250, but still haven't gotten a manual for it yet.
Need to know the type and capacities for the diffs, transfer case and the Getrag.
TIA.
"Obama = Hoax and Chains"
bmoeller is offline
post #2 of 24 (permalink) Old 01-08-2011, 07:50 PM
CAPACITIES:
Engine, without filter..........11 quarts [1]
Cooling System, Initial Fill..........14.8 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A500 Initial Fill..........4.1 quarts
Automatic Transmission, A518(46RH) Initial Fill..........4.1 quarts
Automatic Transmission, A998(31RH) Initial Fill..........4.1 quarts
Automatic Transmission, A999(32RH) Initial Fill..........4.1 quarts
Automatic Transmission, Total Fill
3 speed A999(32RH)..........8.6 quarts
3 speed A998(31RH)..........8.6 quarts
4 speed A518(46RH)..........10.2 quarts
4 speed A500..........10.2 quarts
Manual Transmission, ..........7 pints
Manual Transmission, NP2500..........4.1 pints
Manual Transmission, NP435..........7 pints
Manual Transmission, NV4500..........8.1 pints
Differential, Spicer 44 Front..........5.8 pints
Differential, Spicer 60 Front..........6.6 pints
Differential, Chrysler Rear..........4.5 pints
Differential, Dana 60 Rear..........6 pints
Differential, Dana 70 Rear..........7 pints
Transfer Case, NP241HD..........6 pints
Transfer Case, NP205..........4.5 pints
Transfer Case, NP208..........6 pints
Transfer Case, NP241LD..........4.7 pints
[1] Add extra oil when replacing filter. After
refill check oil level.
Syn-Herb is offline
The Following User Says Thank You to Syn-Herb For this addition to TDG:
bmoeller (01-10-2011)
post #3 of 24 (permalink) Old 01-10-2011, 10:51 PM Thread Starter
bmoeller's Avatar
Excellent! Thanks!
bmoeller is offline
post #4 of 24 (permalink) Old 01-12-2011, 12:34 AM
Make sure when you are filling the Getrag to overfill it. Total capacity of 5 quarts. Easiest way to do this is to remove the shifter and pour it in. Some people remove the top bolt on the PTO cover and fill it through there. It take 5w30 engine oil.
Moose: 1991 Dodge w250 5.9 Intercooled Cummins, Getrag 360. Bosch 190 injectors, 4" exhaust, 3200 spring, inj pump tweaked.
Canadian Club Member 61
Last edited by Ruralcruiser007; 01-12-2011 at 12:37 AM. Reason: Added what oil it uses.
Ruralcruiser007 is offline
post #5 of 24 (permalink) Old 01-12-2011, 12:45 AM
gone fishin!
you run 5w30 in the trans?????? i thought they ran light gear oil...... guess not.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #6 of 24 (permalink) Old 01-12-2011, 02:55 AM
I prefer 85W-140 for the differentials and 4 speeds, haven't run a 5 speed but the recommend is synthetic, the only oils left that have the zinc for flat lifters on the engine are Delo 400 and Walmart Universal (thank the low sulfur legislation), no known problems with any coolant, DOT 3 brake fluid, power steering fluid, +4 ATF - Dexron slips without the friction modifier (if it does not feel the same, suck a second gallon out after a road test. Honda recommends 4 partial changes for contamination with non-Honda approved ATF), 205 transfer case (cast iron ) same as differentials, chain drive transfer case - most are happy with ATF but some have special needs with the torque bias clutches. Moly-grease for the chassis that vintage and acceptable for u-joints, white grease for body hinges (hood, door, tailgate).
Not in the manual - ATF is an excellent substitute for the white grease for hinges, latches and keeping corrosion off the battery terminals. Used ATF sprayed on the bottom and in the rocker panels with an undercoating gun slows rust without being real messy.
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 24 (permalink) Old 01-12-2011, 05:22 PM
I have seen so many people ruin their manual transmissions due to using the wrong fluid.
Syn-Herb is offline
post #8 of 24 (permalink) Old 01-12-2011, 07:37 PM
Nadir's Avatar
Synchromesh in the Getrag.
Nadir is offline
post #9 of 24 (permalink) Old 01-12-2011, 07:41 PM
BlowinSmoke's Avatar
My Getrags got 75w-90 in it right now.
BlowinSmoke is offline
post #10 of 24 (permalink) Old 01-12-2011, 08:25 PM
75w-90 in a Getrag, is this the NV3500 5-sp ? Requires Synchromesh 5w-30 synthetic
Syn-Herb is offline
Is this actually correct? Michael1160 2008-2010 6.4L Power Stroke 7 07-18-2010 01:05 AM
Which parts are correct ? M123KT-450 6.5L Diesel Engine 16 06-09-2010 04:19 AM
Pressure or power not sure of correct term changing tranny fluid gobyslayer 5.9L Cummins (2003-2007.5) 4 03-14-2008 12:55 PM
Need to correct speedo worktruck 2003-2007 6.0L Power Stroke 7 05-23-2006 01:53 AM
Being politically correct LargeCar The Parking Lot 1 03-01-2006 06:10 PM
